Pages: [1] 2 3  All   Go Down
Author Topic: V6 Multi-Ram  (Read 12124 times)
V6 Multi-Ram
« on: 25 January 2017, 10:45:10 »
Are they the same across all V6? - Can I source pipework of a 3.0/2.5 for my 3.2?
Need to get it from a breaker, need all pipework as bit on my 3.2 is bust. Vacuume loss means terrible MPG. Around 20!
Is it best to seal vac leak off or just leave it?
« Last Edit: 25 January 2017, 10:51:02 by tunnie »
Re: V6 Multi-Ram
« Reply #1 on: 25 January 2017, 10:50:39 »
VAC leak source...
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: V6 Multi-Ram
« Reply #2 on: 25 January 2017, 10:54:17 »
Seal any vacuum leaks off  :y
I pretty sure all v6 vacuum pipes are the same if they came off a car with 2 vacuum reservoirs.
Re: V6 Multi-Ram
« Reply #3 on: 25 January 2017, 10:58:38 »
Left it with leak for some time  :-X
Wondered why I only got 18 on the gallon when I took it to work  ;D
Re: V6 Multi-Ram
« Reply #4 on: 25 January 2017, 11:03:33 »
That sounds about the same as when my multiram packed up (as diagnosed by Kev in the car park of the curry house, IIRC ;D)..
Broken nipples, never good.
Re: V6 Multi-Ram
« Reply #5 on: 25 January 2017, 11:04:02 »
Yes, that would knacker the economy (and the performance, the heater, possibly the brake servo..).
Pretty sure you could source the pipe from most V6s. Best to make it from a long plenum model in case they changed the location of the union on the plenum.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: V6 Multi-Ram
« Reply #6 on: 25 January 2017, 11:07:01 »
Vacuum pipe to plenum length is the same on all v6's Kev  :y
The only pipe that a different length is the one underneath to the throttle body  :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: V6 Multi-Ram
« Reply #7 on: 25 January 2017, 11:07:35 »
What you like  ::) ;D
Re: V6 Multi-Ram
« Reply #8 on: 25 January 2017, 11:17:19 »
Thanks all  :y
Yes noticed all of these as well!  :(
Re: V6 Multi-Ram
« Reply #9 on: 25 January 2017, 11:42:24 »
Quick question the actual valve it self, it looks like it's there to join the two larger bits of pipework together, with this outlet at the top.
Is it easy to replace just this valve? When I looked the plastic is all super hard and does not look like it easily comes apart.
Soak it in or pour over hot water?  :-\
« Last Edit: 25 January 2017, 11:45:32 by tunnie »
Bojan
  • Croatia, Slavonski Brod
    • MV6 3.0
Re: V6 Multi-Ram
« Reply #10 on: 25 January 2017, 11:57:43 »
Brake vacuum pipe on 2.5/3.0 V6 is different from 2.6/3.2 V6.
Older one has two nipples (one for Mulitrams, other for SAI), later has only one nipple (as no SAI).
Re: V6 Multi-Ram
« Reply #11 on: 25 January 2017, 12:11:03 »
Recover the snapped off part fro the rubber coupling and measure the OD.
Drill into the valve assembly around 4-5mm with the correct size drill to march the OD.
Insert the snapped off part into the hole (it should be a reasonably comfortable fit) with some suitable glue applied
The  rotate the whole valve assembly so it points downwards like it should do.
Re: V6 Multi-Ram
« Reply #12 on: 25 January 2017, 14:05:52 »
Worth checking / resetting LT fuel trim if it's been leaking a while?  :y
Re: V6 Multi-Ram
« Reply #13 on: 25 January 2017, 15:03:05 »
Thanks, did not think of that.  :-[
I'll check my drill bits, do you think the snapped off part within the T piece will be long enough, once re-inserted?
Trip to KW or Little Fatty then for a tune up once sorted.  :)
Thanks, will ensure I get replacement of DBW then. But i'll try fixing current one first.  :)
Re: V6 Multi-Ram
« Reply #14 on: 25 January 2017, 15:41:15 »
Yes, successfully done this a few times on a few cars, you effectively lose about 4-5mm so not a huge percentage smaller :y
Pages: [1] 2 3  All   Go Up
