Pages: [1] 2 3 4 5 6 7   Go Down
Author Topic: Iv fooked it i think  (Read 34249 times)
Elite_L0ver
  • Eastleigh, Hampshire
  • On too Omega #2
    • 99 2.5 V6, 03 2.2 CD FL
« on: 24 February 2017, 18:08:40 »
Right iv had a go today at changing the cam kit got brand new gates kit £117+ vat
Fitted it had issue with it vibrating whilst going over top cams i have removed and reinstalled the tensioner upbteen amout of times and i was turning the engine by hand and now the bottom cam is turning but top have stopped turning
Simple question really have i fooked it
Likes My Music LOUD!!!!
Elm327 code reader And OP COM available Locally PM Me
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
Re: Iv fooked it i think
« Reply #1 on: 24 February 2017, 18:14:14 »
Have you ran the engine or is this all by hand?
Elite_L0ver
  • On too Omega #2
« Reply #2 on: 24 February 2017, 18:19:56 »
It was done buy hand
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #3 on: 24 February 2017, 18:24:11 »
Remove and start again
Don't turn the engine over with the ignition.
Fingers crossed  ;)
Elite_L0ver
  • On too Omega #2
« Reply #4 on: 24 February 2017, 18:27:22 »
Fingers crossed  ;)
I cannot turn the top cams
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #5 on: 24 February 2017, 18:33:04 »
Fingers crossed  ;)
Foook
Somebody with more experience should be along soon  :(
X30XE
  • UK
    • 740i,728i,S320 & Disco
« Reply #6 on: 24 February 2017, 18:46:50 »
Assuming you've only turned the engine by hand, and thus you haven't bent any valves the only reason I can think of that the cams won't turn is because they're hitting the pistons. ie - it's timed wrong.  :-\
Omegatitis : [in remission]
Viral_Jim
  • Telford
    • Too many, mostly broken
« Reply #7 on: 24 February 2017, 18:50:24 »
Fingers crossed  ;)
i suspect you may have to re-time the engine from scratch. Iirc there's a piece in Haynes about this but I think you'll need a gauge to find TDC on cylinder 1.
As said I think the only reason it won't turn at all is piston-on-valve action :-\
  • Online Online
« Reply #8 on: 24 February 2017, 18:54:20 »
You have removed the cam lock?
« Reply #9 on: 24 February 2017, 19:02:01 »
Elite_L0ver
  • On too Omega #2
« Reply #10 on: 24 February 2017, 19:06:22 »
;D ;D ;D
 ;D ;D ;D not that stupid (although feel it at moment)
Elite_L0ver
  • On too Omega #2
« Reply #11 on: 24 February 2017, 19:08:10 »
I hope so but i ran out of light theres some oil in plug wells so got to clean that up first then removed all plugs n hope i can retime it
Viral_Jim
  • Telford
« Reply #12 on: 24 February 2017, 19:10:57 »
Do you have a workshop manual that covers the 2.2? its not in the Omega Haynes one, because, well ..... Haynes
I have a frontera manual, which does cover the 2.2. Let me know if you want anything emailed.
Oil in the wells is an easy (ish) one to solve, new gasket and clean the breathers. Although probably the focus should initially be on getting it running  ;D
Elite_L0ver
  • On too Omega #2
« Reply #13 on: 24 February 2017, 19:18:22 »
That is the main focus but am going to have ro remove plugs to find tdc n anything you think will help with retiming the engine please ANYTHING :( :( :-[ :'( i need her running at least by monday
  • Online Online
« Reply #14 on: 24 February 2017, 19:19:34 »
;D ;D ;D
You laugh... I had a hell of a job trying to turn the crank first time I tried it on my own... turns out I had left the car in gear and couldn't turn the crank any further than the slop in the flywheel :-[
Point is, don't overlook the obvious ;)
Pages: [1] 2 3 4 5 6 7   Go Up
Page created in 0.024 seconds with 20 queries.
