Author Topic: Re: 2.5 TD Power Steering Hose  (Read 499 times)
350sb
  • London
    • X reg 2.5 TD GLS
« on: 11 March 2017, 08:40:05 »
Hi Guys,
Has anyone replaced a power steering return hose on a 2.5 diesel before? My return hose has a cut on the section next to the battery and is leaking badly when turning the steering.  I purchased a so called genuine part from Vauxhall-Car-Parts and they sent me a pipe (part no. 24405033) with a fitting on one end only but with no fitting on the other end to go to the pump.
Any help will be appreciated.
Thanks
Chazza12
  • south yorkshire
    • 1996 2.0 16v CD estate
« Reply #1 on: 11 March 2017, 21:25:40 »
If i remember right i had the same on another car ive had, you only get the pipe and on fitting the other end you need a crimp kit its a cap you fit over the pipe and crimp it to the conetor were the old pipe was fitted. think you can buy them on bay for around 20 and they come with the fittings. some people just use a jubilee but a good make not one of these cheap ones.
Fuse 19
« Reply #2 on: 13 March 2017, 15:51:41 »
If its only the return line then a suitable piece of rubber and a jubilee clip should suffice as the oil is hardly under any pressure.
350sb
  • London
    • X reg 2.5 TD GLS
« Reply #3 on: 14 March 2017, 20:05:33 »
Thanks Guys, hopefully should have it sorted on Friday.
mandula
  • Finland
    • Opel Omega -03, Z22XE man
« Reply #4 on: 08 May 2018, 08:09:43 »
Anybody remembers inner/outer diameter of those hoses that are attached to power steering pump reservoir?
Page created in 0.129 seconds with 21 queries.
