Pages: [1] 2 3 4 5 6 7   Go Down
Author Topic: V6 just dies no pedal codes  (Read 39284 times)
omega2018
    • MercCL500 Omega2.6ManElit
« on: 28 May 2017, 17:28:35 »
after about 20 minutes happy driving the engine just stopped, i glided to a stop and re-started it, fine then 5 minutes later same again. And again.  No pedal trick codes or eml light either time.   will put my cheap scanner on it tomorrow but any ideas?  doesn't seem similar to the crank sensor that went 12,000 miles ago. cam sensor perhaps?  or oil in the plugs?  half tank of petrol.  car now done 102K.
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
Re: V6 just dies no pedal codes
« Reply #1 on: 28 May 2017, 18:01:17 »
Sounds very similar to what happened to mine a couple of months ago. It was the crank sensor.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #2 on: 28 May 2017, 18:05:47 »
Disconnect the MAF sensor and see if that helps. The EML will be on, but it will go out once the MAF is reconnected
omega2018
« Reply #3 on: 28 May 2017, 18:37:04 »
thanks could be that but when mine went before there was  a warning sign - failure to start on first turn about 1 in 10 goes, then when it went it was an hour after I had parked the car from a long run  and it would not fire at all.  then another hour later, with the recovery truck attending, it fired straight away.  this time it has different symptoms.
only slightly out of the ordinary thing today was hot weather, air con on full and start stop traffic driving before it died , temperature gauge was a bit high - will try unplugging MAF but how long to run without it connected?
« Reply #4 on: 28 May 2017, 18:43:32 »
Until you plug it back in ;)
omega2018
« Reply #5 on: 28 May 2017, 18:46:10 »
forgot to mention the engine was at low revs (<2000) each time it died so I think so MAF could be the problem.
omega2018
« Reply #6 on: 30 May 2017, 15:32:23 »
plugged in the cheapo elm scanner today, no error codes no problems showing but more data than i know what to do with.  anything i should look for?  air flow looks ok, increases with revs as you'd expect. unable to reproduce stall problem but this was just testing while stationary:
OBD-II Diagnostic Report
   Phone:
   Fax:
   Email:
   Internet:
Customer Address    Vehicle Info
   Make:
   Model:
   Year:
   Registration-No:
Vehicle Information (Mode 09)
Description   Count
System Status (Mode 01)
Description
OBD Type
     OBD Type    EOBD
Trouble Codes
     MIL Status    Off
     Number of DTCs    0
Continuous Monitoring tests
     Misfire    Supported    Complete
     Fuel System    Supported    Complete
     Comprehensive Components    Supported    Complete
non-Continuous Monitoring tests
     Catalyst    Supported    Complete
     Heated Catalyst    Not Supported
     Evaporative System    Not Supported
     Secondary Air System    Not Supported
     A/C System Refrigerant    Not Supported
     Oxygen Sensor    Supported    Complete
     Oxygen Sensor Heater    Supported    Complete
     EGR System    Not Supported
Fuel System Status
     Fuel System 1 Status    closed loop
     Fuel System 2 Status    closed loop
Diagnostic Trouble Codes (Mode 03, 07, 0A)
Description
Stored Diagnostic Trouble Codes (DTC) (Mode 03)
     No Trouble Codes
Pending Diagnostic Trouble Codes (DTC) (Mode 07)
     No Trouble Codes
Permanent Diagnostic Trouble Codes (DTC) (Mode 0A)
     No Trouble Codes
Freeze Frame Data (Mode 02)
Description   Value   Units
Location of Oxygen Sensors
Location of Oxygen Sensors   State
Bank 1 - Sensor 1    Present
Bank 1 - Sensor 2    Present
Bank 1 - Sensor 3    Not Present
Bank 1 - Sensor 4    Not Present
Bank 2 - Sensor 1    Present
Bank 2 - Sensor 2    Present
Bank 2 - Sensor 3    Not Present
Bank 2 - Sensor 4    Not Present
Oxygen Sensor Test Results (Mode 05)
Description   Value   Min   Max   Units   Result
Monitored Test Results (Mode 06)
TID $01, CID $05 - Values defined by manufacturer    55       140       Pass
TID $01, CID $06 - Values defined by manufacturer    56       140       Pass
Live Data (Mode 01)
   Description   Value   Units   Min   Average   Max
   03 - Fuel System Status
        Fuel System 1    closed loop    -    2.00    2.00    2.00
        Fuel System 2    closed loop    -    2.00    2.00    2.00
   04 - Calculated Load Value    2    %    2.35    2.35    2.35
   05 - Engine Coolant Temperature    208    °F    208.40    208.40    208.40
   06 - Short Term Fuel Trim - Bank 1    -1.6    %    -1.56    0.65    3.13
   07 - Long Term Fuel Trim - Bank 1    1.6    %    1.56    1.56    1.56
   08 - Short Term Fuel Trim - Bank 2    -3.1    %    -3.13    -3.13    -3.13
   09 - Long Term Fuel Trim - Bank 2    0.8    %    0.78    0.78    0.78
   0C - Engine RPM    665    rpm    643.75    655.25    664.75
   0D - Vehicle Speed    0    mph    0.00    0.00    0.00
   0E - Ignition Timing Advance for #1 Cylinder    2    °    2.00    3.20    4.50
   0F - Intake Air Temperature    136.40    °F    136.40    136.40    136.40
   10 - Air Flow Rate    0.46    lb/min    0.46    0.46    0.46
   11 - Absolute Throttle Position    2.0    %    1.96    1.96    1.96
   14 - Bank 1 - Sensor 1
        Oxygen Sensor Output Voltage    0.110    V    0.09    0.19    0.51
        Short Term Fuel Trim    -0.8    %    -0.78    0.47    1.56
   15 - Bank 1 - Sensor 2
        Oxygen Sensor Output Voltage    0.710    V    0.60    0.67    0.71
        Short Term Fuel Trim    99.2    %    99.21    99.21    99.21
   18 - Bank 2 - Sensor 1
        Oxygen Sensor Output Voltage    0.120    V    0.09    0.23    0.71
        Short Term Fuel Trim    -0.8    %    -1.56    0.00    1.56
   19 - Bank 2 - Sensor 2
        Oxygen Sensor Output Voltage    0.690    V    0.59    0.66    0.71
   21 - Distance Travelled While MIL is Activated    0    miles    0.00    0.00    0.00
« Reply #7 on: 30 May 2017, 17:52:55 »
Before you unplug, can you get a MAF reading (ideally in kg/hr) at idle, and post up
  • Auckland
    • Mazda MPV
« Reply #8 on: 30 May 2017, 21:18:29 »
about 12.5 kg/hr if my maths is up to scratch (x 60min / 2.2 lb/kg)
omega2018
« Reply #9 on: 31 May 2017, 14:04:47 »
well spotted and good maths
                          min   avg    max
here are the Nov 2013 figures, same engine at 78K miles (currently 102K)
0.40    lb/min    0.36    0.38    0.43
0.36    lb/min    0.36    0.37    0.40
All figures would have been at idle I think.  So up a bit from 2013, maybe the colder air in november?  i have some graphs from 2013 for a run I did , 13 variables (fuel trim, ign timing, oxy sensor etc..) but missing air flow unfortunately.  as i said though this time the air flow seemed to rise with revs as you would expect.
Just took the MAF out, looks clean but will spray with contact cleaner.  tried to remove the actual sensor from the large tube, i have some security bits to undo the poled screws but they are 5 sided not the usual 6 so can't undo them >:(.
« Last Edit: 31 May 2017, 14:16:41 by migmog »
« Reply #10 on: 31 May 2017, 18:22:54 »
DONT!!!
« Reply #11 on: 31 May 2017, 18:24:40 »
Seems about right for a smaller variant v6 :)
So, I'd be suspicious of crank sensor in this case ;)
omega2018
« Reply #12 on: 31 May 2017, 21:33:57 »
just took it for a 28 mile motorway run after the MAF clean, no problems in fact mpg looks slightly better but on return I left it idling, lumpily, and it stalled. twice.  plus now an error code at last
PO305 cylinder 5 misfire on my scanner and on the pedal trick 2 codes:
P0300 random misfire and P0305 cylinder 5 misfire.
i suspect MFL might cause that but i need to check the plug wells for oil leaks, looks like i have to undo the cover on the fl, before it was just pull the plug leads.
doesn't feel the same as the last crank sensor failure, it always seems to start ok.
« Last Edit: 31 May 2017, 21:39:57 by migmog »
« Reply #13 on: 01 June 2017, 11:21:37 »
Two bolts frees the cable tray and two more frees the coilpack... hardly difficult ::)
All six plugs can be changed in half an hour, including a cuppa ;) assuming of course that the plug wells aren't full of oil/water :D
omega2018
« Reply #14 on: 01 June 2017, 16:06:46 »
its not difficult but its a lot more hassle than the 5 secs it takes on a pfl and more than you describe above >:( .  Fl - undo two bolts, get two slightly larger bolts and screw them what looks like the thread of the ones you have just removed, pull on both bolts to half pull out the coil pack, now try and unplug the coil connector which is fiddly you have to press a latch you can't see, now unclip the two cooling pipes in two locations and push the pipes out of the way, now undo two bolts to try and move the fuel pipes which don't move anyway, now try and manoeuvre out the coil pack. Done.  but now you have to replace.  and that's just the drivers side without having to move a cable tray.
anyway i have now checked the drivers side, cylinder plug 1 is bone dry, 3 and 5 had a tiny amount of oil at the bottom, maybe 1/4 teaspoon or less.  the rubbers look fine.  surely not enough to cause a misfire is it, not to mention the stalling problem?
I cleaned out the oil and connectors , and slightly upped the torque on all the cam gasket bolts from 8 to 9nm (two are pigs to get at).   i don';t have the gaskets or the will to replace them at the moment but i will check it again later.
Pages: [1] 2 3 4 5 6 7   Go Up
Page created in 0.341 seconds with 20 queries.
