Author Topic: Megamos interior light wiring  (Read 997 times)
ati88
  • Hungary
    • Vectra
« on: 29 May 2017, 10:04:58 »
Hi all,
I've got a "Megamos" interior light unit with map lights (2x). It has a 9 pin connector. I'd like to install this into my Vectra A which only has 2 pins to connect (12V, GND).
I couldn't find any wiring diagrams for this light unit and so far I could only "reverse engineer" two pins: 12V and GND for the main light part.
The unit looks like this:
http://i.ebayimg.com/00/s/Nzk0WDE2MDA=/z/QrIAAMXQUaJRm0Vh/$T2eC16JHJGsFFMsZgL3rBRm0VhERGQ~~60_1.JPG
http://i.ebayimg.com/images/a/T2eC16hHJF0E9nmFTL6RBP8tdcL39Q~~/s-l300.jpg
It has two serial numbers: GM 09104492 (the case) and 70505013004 (electronics).
What I found out is that this light unit used to be shipped with Omega B's, that's why I'm here.
If anyone could provide me a pin layout or any circuit diagram that would be a great help!
Thank you a lot!
Regards,
Attila
ati88
  • Hungary
    • Vectra
Re: Megamos interior light wiring
« Reply #1 on: 29 May 2017, 16:01:12 »
So I found a wiring scheme for the Omega here: http://www.vectra16v.com/slp/slp_omega_b_mj01.pdf
On page 14 I found some very similar 9 pin connector with 5 light bulbs (I've got 4 only).
According to the wiring if I apply 12V on pin 9 and GND on pin 1, two of the lights turn on. That's okay.
However I can't figure out the reading/map light stuff with the press buttons. It should be something like pin 8 goes to GND and pin 2 to 12V, but thats not enough.
ReLLaXX
  • Romania
    • Opel Omega B, Sedan, 2003
« Reply #2 on: 29 May 2017, 20:55:50 »
If you can wait a few days I will get the car back and will be able to measure each pin on the spot. If you dont find a solution until then I will be glad to help.
Considering the fact that there is no absolute truth... I may be relatively... right!
ati88
  • Hungary
    • Vectra
« Reply #3 on: 29 May 2017, 21:54:17 »
Sure, I can wait. Thanks a lot in advance! :)
ati88
  • Hungary
    • Vectra
« Reply #4 on: 10 June 2017, 12:09:24 »
Hi!
Did you happen to have some time measuring the pins? I'm still looking for help!
Vega
  • The Netherlands
    • Omega Saloon 3.2
« Reply #5 on: 10 June 2017, 13:52:30 »
9=Red=12V constant
8=Braun=grond
2=Black=12V ignition
1=Grey/Black=from Central locking, turns on the light.
ati88
  • Hungary
    • Vectra
« Reply #6 on: 12 June 2017, 18:30:24 »
Thank you Vega! That was helpful!
I did a truth table for these four pins: pin 1, 2, 8 and 9 and for my Vectra A I'm going to need:
pin 1 - to be connected to the current GND cable (this is switched from open doors / light switch)
pin 2 - to be connected to the current 12V cable (this turned out to be constant 12V)
pin 8 - to be connected to constant GND, like from chassis
pin 9 - to be connected to the current 12V cable (this turned out to be constant 12V)
Will wire it tomorrow and see how this theory works.
Page created in 0.106 seconds with 21 queries.
