Author Topic: Indicators stay on n/s  (Read 384 times)
dmh12345
  • Wakefield
    • Omega 2.5TD GLS
« on: 25 June 2017, 22:42:25 »
Hi
Need help with indicator issue. Remote stopped working on key so alarm goes off when open door. Indicators flashed before but no sound so ok for now. Left indicator now stays on unless remove fuse. o/s then flashes on but n/s flashes courtesy light left side fuel warning and brake warning light which I assume is because not going through hazard switch. Replace hazard switch as told only live to indicators. Did not cure at first but following morning all seemed to work again. Now n/s indicators on again. Any ideas
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Indicators stay on n/s
« Reply #1 on: 26 June 2017, 00:13:46 »
If it was me, and this is a long shot, remove Battery connection overnight and refit in the morning (Radio Code?).
Also, as a temp measure, lock the car by pushing down the Drivers door button via the the rear door, this will stop the alarm from being activated when opening the car next time.
Edit: remove the battery connection before locking the car, then lock all doors.
« Last Edit: 26 June 2017, 00:19:12 by zirk »
« Reply #2 on: 26 June 2017, 12:25:38 »
White/grey relay at very top of passenger footwell wingside controls the indicators for the alarm. Could be that one
Page created in 0.101 seconds with 21 queries.
