Author Topic: Noisy differential?  (Read 3159 times)
terry paget
  • Midsomer Norton Somerset
    • 1 Omega 3 Astras 2 Vectra
Re: Noisy differential?
« Reply #45 on: 06 August 2017, 12:11:23 »
Always support the body using the jacking points and jack the suspension as required ;)
Thank you, clearly safer practice. Will do henceforth.
neil74
  • newport
    • 2.6 elite estate.
« Reply #46 on: 06 August 2017, 15:43:14 »
My diff is leaking quite well. i wonder how long before it seizes and i end up in a ditch with the car resting on its roof..
terry paget
« Reply #47 on: 06 August 2017, 18:37:39 »
If it's leaking well you know where the leak is, presumably one of the 3 seals. Why not top it up as a temporary measure, then when you have time change the faulty seal.
terry paget
« Reply #48 on: 08 August 2017, 10:11:13 »
Reading Haynes again on which bolts should be replaced on this job, I appear to have failed to replace 9 bolts, but I was right not to replace the drive shaft to hub bolts. Some bolts should be replaced if they have torx heads, but not if they have hexagon heads.
I suppose Haynes is based upon GM instructions to dealers, who have all these items in stores so it's not a problem. I'll wager independent garages do not bother, nor do some private owners with 17 year old cars, even if parts are still available.
25 years ago I had the diff changed on my Peugeot 505 GTI family estate by a Bath main dealer. It cost me over 1000, and was returned with a wobbly rear wheel. I complained, and after many phone calls I learned they had used a slide hammer to remove the drive shafts, and had bent one. Instead of replacing it, they machined the hub to correct for it.
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #49 on: 08 August 2017, 12:32:21 »
Brilliant, and then they wonder why people don't trust garages. :-X :y
mandula
  • Finland
    • Opel Omega -03, Z22XE man
« Reply #50 on: 21 June 2018, 08:26:32 »
How to remove this noise?
Oil change didn't fix it, all tooth surfaces are smooth and no big particles found from magnet.
https://www.youtube.com/embed/w7rt17n7A44
« Reply #51 on: 21 June 2018, 09:35:30 »
Some play should be expected, to allow for fluid and heat. Flange nut is tightened for tension rather than torque but not sure if that would cause rotational play :-\
Two choices... Obtain and fit a new pinion and crown... Either brand new or a matched used pair.
Just as easy to throw another diff in  :y
« Reply #52 on: 21 June 2018, 09:42:39 »
Just as easy Much easier to throw another diff in  :y
FTFY. :y
Pages: 1 2 3 [4]  All   Go Up
Page created in 0.258 seconds with 22 queries.
