Author Topic: V6 misfire, water in no. 6 and scuttle foam sodden  (Read 1050 times)
terry paget
  • Midsomer Norton Somerset
    • 5 omegas all petrol & man
Re: V6 misfire, water in no. 6 and scuttle foam sodden
« Reply #15 on: 03 January 2018, 21:47:05 »
Inspired by charlieboy's exhaust thread, I checked this car's history. In December 2016 it suffered a misfire in no. 6, which I 'cured' with a plug change. I did not trace the cause, the sodden scuttle foam. I hope this year I have rectified the underlying cause.
Sir Tigger QC
    • BMW 530d & 2 Fords
« Reply #16 on: 03 January 2018, 23:38:02 »
You havn't cured the leak though Terry, and now without the foam it is harder to tell if your scuttle is leaking or not.  ::)
Granted you havn't got the foam storing the water and dripping all over your dispack though....  :)
JC is not The Messiah, he's a very naughty boy!!
terry paget
« Reply #17 on: 06 January 2018, 11:52:01 »
Not really.
Make sure that both parts of the trim are securely attached to the base of the windscreen.
When I got the Project MV6 from James he had just replaced the coil packs. After a little while I discovered that the scuttle foam was soaking wet and that the windscreen trim was insecure. I ended up pulling the trim off (and separating both parts) and giving it a good scrub to get all the moss out.
Since I did that the foam has remained dry. Pulling the foam off doesn't prevent the leaks it merely gets rid of the evidence..........
Thanks for the enlightenment. I used to believe windscreen trims were glued on. Son Jonny recently had a windscreen replaced and complained to me that the side trims was coming out. I contacted Autoglass, they came along, said it should be a push fit, then glued it in place. In the past I have glued on loose bottom trims. Next time I shall pull the bottom trim off and reseat everything properly.
  • Millennium Man
    • The missus mad
« Reply #18 on: 06 January 2018, 14:54:32 »
Not really.
And that will cure it, and without having to sacrifice the sound deadening (which doesn't cure the problem anyway) :y
I don't tolerate bickering, and I'm always grumpy.
And Lizzie Zoom says I'm a heartless bastid...and she's absolutely correct!
ajsphead
  • North Somerset
    • Omega 2.2 DTi estate
« Reply #19 on: 06 January 2018, 16:11:14 »
Not really.
Recently had autoglass to replace a windscreen on mine, what a laugh that was after taking 3 attempts. The parts do all clip together and no glue should be necessary. The final pair of fitters explained that if you don't have experience of doing Omegas and fit everything together in the right order and the right direction then the trims will keep coming loose and also not sit correctly.
Fraggles Rock
  • United Kingdom
« Reply #20 on: 06 January 2018, 16:41:34 »
The Sound deadening basics: a) doesn't work and b) it holds about a litre of water.
Does removing it stop the scuttle leaking? No. But it does stop the water from collecting and dripping onto the coil pack/camcover.
So is removing it an effective cure to the issue of wet coil packs and plug wells? Yes.
We will have to agree to disagree on the technical merits of spending an afternoon trying to get 17 year old heat soaked plastics to fit neatly versus two minutes spent removing some soggy foam ;)
Sir Tigger QC
« Reply #21 on: 06 January 2018, 17:01:30 »
Or you could spend 2 minutes putting a bead of silicon on the edge of the cabin filter box where the end of the scuttle sits.  ;)
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #22 on: 06 January 2018, 19:21:23 »
I'm sure a member previously hand-crafted an extra plastic cover, held on by some of the existing plenum bolts, to belt-and-braces the job.
  • Chatham, Kent
  • Rover Metro 1.8VVC
    • 3.0l Elite estate
« Reply #23 on: 06 January 2018, 20:09:52 »
I'm with you. The original trim is supposed to divert the water away from stuff underneath it. It doesn't do this very well, and the foam makes the problem much worse. Removing the foam makes no difference to the noise inside the car, and eliminates any issues scuttle leaks might cause.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #24 on: 07 January 2018, 10:07:55 »
I made an aluminium tray bolted to the plenum to divert water.
  • Millennium Man
    • The missus mad
« Reply #25 on: 07 January 2018, 10:08:37 »
But either way, you still need to fix the leak. A fix that makes the foam removal unnecessary.  Personally, I'd rather fix a problem properly, but everyone is entitled to do as they please on their own property :y
And, as a sound deadening, it works ok. Its easy to tell, from the cabin, a car that's had the foam removed.
  • Millennium Man
    • The missus mad
« Reply #26 on: 07 January 2018, 10:10:52 »
That doesn't fix the usual cause of this, which is water running down screen, and under the lower seal (because its not properly clipped on the windscreen), and then dripping on back of engine, and some soaking into foam.
Page created in 0.117 seconds with 21 queries.
