Author Topic: Radio on SAFE  (Read 11217 times)
Berniemc1356
  • East Ayrshire
    • Omega 2l
Radio on SAFE
« on: 17 January 2018, 11:03:49 »
Hi
Recently my Omega wouldn't start because of a flat battery. After I charged it and connected it back up I discovered my radio would not let me put in my code to remove it from the SAFE mode. All I get on the display is 7 SAFE. I have tried removing and replacing the battery to no effect. If it means a replacement radio/cd player I would appreciate a lisy of suppliers.
Re: Radio on SAFE
« Reply #1 on: 17 January 2018, 11:22:00 »
What radio unit is fitted?
"7 Safe" means you have seven attempts left, sure you are entering the right code?
Berniemc1356
  • East Ayrshire
    • Omega 2l
Re: Radio on SAFE
« Reply #2 on: 17 January 2018, 12:50:01 »
Hi
I know that the display 7 SAFE means I have 7 attempts left.  But when I switch off the radio and hold down the AS button and switch on the radio again I am not getting the confirmation  beep which allows me to put in the correct code.
Re: Radio on SAFE
« Reply #3 on: 17 January 2018, 18:39:30 »
Hi
The time you need to leave it powered up to enter the code increases with each wrong code entered
JDX
  • Hersham, Surrey.
    • '02 2.2dti CDX estate.
Re: Radio on SAFE
« Reply #4 on: 18 January 2018, 09:54:32 »
Did you solve the problem?  :y
Berniemc1356
  • East Ayrshire
    • Omega 2l
Re: Radio on SAFE
« Reply #5 on: 19 January 2018, 10:53:59 »
Hi
No I still haven't managed to solve the problem even leaving the radio off for days it still comes up 7 SAFE.  I think it must be a problem with the AS button as I am not getting a conformation beep to allow me to put in the radio code. I fear I may have to buy a new radio/cd player. If anyone can put me in touch with a supplier I would be extremely gratefull.
Re: Radio on SAFE
« Reply #6 on: 19 January 2018, 12:11:17 »
Hi
Radios need leaving with power ON for the increasing number of hours
Re: Radio on SAFE
« Reply #7 on: 19 January 2018, 15:33:47 »
Yeah. Could be up to 10 or 15 mins at 7 that it needs to be on, before it would allow entry.
Berniemc1356
  • East Ayrshire
    • Omega 2l
Re: Radio on SAFE
« Reply #8 on: 20 January 2018, 15:42:12 »
Hi
When you say the radio needs to be on for 10-15 mins is that holding down the AS button or just leaving the radio switched on.
Re: Radio on SAFE
« Reply #9 on: 20 January 2018, 16:32:56 »
Hi
Ignition ON, radio ON
JDX
  • Hersham, Surrey.
Re: Radio on SAFE
« Reply #10 on: 21 January 2018, 18:18:11 »
Did leaving the power on solve it? :y
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Radio on SAFE
« Reply #11 on: 22 January 2018, 10:50:27 »
7 SAFE means radio and ignition switched on for up to 2 hours before another code attempt is possible
Radio & Decoding Technician
www.dndservices.co.uk
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
Re: Radio on SAFE
« Reply #12 on: 22 January 2018, 18:53:52 »
Good job there,s not a coil to burn out then. :D Or is there something else. ???
Berniemc1356
  • East Ayrshire
    • Omega 2l
Re: Radio on SAFE
« Reply #13 on: 23 January 2018, 16:13:37 »
Hi Thanks to everyone to offered advice I finally managed to get my radio/cd working. :y :y :y :y :y
JDX
  • Hersham, Surrey.
Re: Radio on SAFE
« Reply #14 on: 23 January 2018, 16:24:14 »
Good news...  :y
