Author Topic: Door seals  (Read 673 times)
laney101
  • liverpool
    • omega elite v6
Door seals
« on: 26 February 2018, 21:14:54 »
Got brand new front door seals for omega and I notice it goes down glass Channel at door opening end..
Anyone ever swapped one or now how too
sjc
  • Alloa, Scotland
    • M5 ; 3.0 MV6 Manual
Re: Door seals
« Reply #1 on: 05 March 2018, 19:48:37 »
Pretty sure you just slide it down between the glass and the channel.  Pop the door trim off if you want to get in there and check it's properly seated but don't think there's much room for it to go anywhere off course.
Automaticman
  • Neston
  • Saxwood
    • Frontera V6 Omega V6
Re: Door seals
« Reply #2 on: 06 March 2018, 17:29:38 »
Agreed  :y
When ya wanna shoot, shoot, dont talk !
mandula
  • Finland
    • Opel Omega -03, Z22XE man
Re: Door seals
« Reply #3 on: 07 March 2018, 06:07:00 »
Where did you get the seals and at what price?
I'd also like to replace door seals, been looking a bit and could not find any complete sets. Only single seals and prices are astronomical..
laney101
  • liverpool
    • omega elite v6
Re: Door seals
« Reply #4 on: 12 March 2018, 17:15:28 »
Ebay about 30 quid brand new but only passenger available .. I'm gonna fork out for drivers side but that nearer 100 quid
Chazza12
  • south yorkshire
    • 1996 2.0 16v CD estate
Re: Door seals
« Reply #5 on: 15 March 2018, 08:07:13 »
get a left one and cut the joint roll it up and put in hot water in a bucket make sure its really hot. and while it hot and flexible fit to the door frame and when its cooled down, use some rubber fix glue or sealer made by sealer for vehicles seals, leave to dry before closing the door takes around 30 to 60 min to dry. and it's done. sealer is around 8. flexible fix bond for rubber metal and glass.  drys like an elastic band and is black or gray but black for rubber.
laney101
  • liverpool
    • omega elite v6
Re: Door seals
« Reply #6 on: 17 March 2018, 07:02:25 »
Ended up fitting no problem... Not soaking or cutting ... Removed old one ... Used ducks foot to remove clipped in section ... And rest just pulled off...
New seal little bit of washing up liquid in certain areas. Mainly door channel bit of pursueding and went in... Then over all seals and trim with kryto anti squeak gel and not CSR does not has a single creak rattle or noise at all
Page created in 0.105 seconds with 21 queries.
