Author Topic: WANTED - High pressure PAS hose  (Read 423 times)
Dr_Syn
  • Atherton
    • 2001 Omega 2.6CDX Auto
« on: 09 March 2018, 19:50:34 »
Hi,
I'm in desperate need for the high pressure power steering hoses for my 2.6 Omega.  Specifically the ones that run across the front of the car in front of the radiator.  The ones on mine have perforated due to corrosion and now leaking.  I've already obtained the low pressure pipe from an ebay seller, but the high pressure hoses are proving difficult to find.
Thanks.
omegod
  • liverpool
    • 2017 Seat Ateca
Re: WANTED - High pressure PAS hose
« Reply #1 on: 10 March 2018, 09:03:20 »
Can you post a pic of the pipe and I'll see if I can help
biggriffin
  • huntingdon, Hoof'land
    • 02 3.2 mv6 estate.
« Reply #2 on: 10 March 2018, 10:41:59 »
That'll be the metal ones on, it's the cooler
I think it's 10mm pipe, you could use compression fittings and pipe from a hydraulic company.
Hoof'land storeman..
Omega is a barge not a dtm-touren-wagen
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #3 on: 10 March 2018, 12:06:10 »
PM'd
Dr_Syn
  • Atherton
« Reply #4 on: 10 March 2018, 18:08:05 »
I've picked up a set of pipes today thanks to omegod.  Jon was also able to sort me out with a door solenoid and the plastic fittings for the slam panel.  As long as it stays dry tomorrow I'll get stuck into stripping the front end down to get the pipes swapped out.  :y
Dr_Syn
  • Atherton
« Reply #5 on: 11 March 2018, 19:21:13 »
A minor setback.  The high pressure pipe that runs from the pump and across the front of the car that I got is not comaptible with my car, so the hunt goes on.  I have managed to establish now though that the pipe I do require is labelled DL, but is no longer manufactured by Vauxhall.
So the hunt continues.
biggriffin
« Reply #6 on: 11 March 2018, 21:43:21 »
The pipe, needs to be from either 2.6/3.2,. Any other won't fit.
Page created in 0.098 seconds with 21 queries.
