Author Topic: Rear brake pads  (Read 3704 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Rear brake pads
« on: 10 March 2018, 15:17:01 »
Nick's adventure in France replacing rear brake pads using nails and bits of wood have prompted me to check my brake pad stock. I find I have 3 boxes of front pads and none of rear pads. My TC supplier Drive Vauxhall Avon Street  Bristol had no stock when I last enquired. I must order some, so need a part number. I have an old box here numbered 93169001  16 05 618  GR.06.311. Is that correct?
biggriffin
  • huntingdon, Hoof'land
    • Vectra in a posh frock.
Re: Rear brake pads
« Reply #1 on: 10 March 2018, 15:24:44 »
A certain admin, might have a few sets. ;)
Hoof'land storeman.
Enceladus
  • London
Re: Rear brake pads
« Reply #2 on: 10 March 2018, 18:13:43 »
Original GM pads with fitting kit for can be had here for £9.95 delivered. For non vented. GM Nr 16-05-026 9193476.
terry paget
    • 3 Astras 2 Vectra
Re: Rear brake pads
« Reply #3 on: 10 March 2018, 20:27:04 »
Many thanks - problem solved.
johnnydog
  • Online Online
  • Lancashire
    • 2.6 & 3.2 sal, 3.2 est
Re: Rear brake pads
« Reply #4 on: 11 March 2018, 01:11:32 »
The pads can be obtained easily almost anywhere - it's the pins and clips for vented discs that are like gold dust.....
2002 3.2 Elite saloon, 2003 3.2 Elite estate, 2003 2.6 Elite saloon
terry paget
    • 3 Astras 2 Vectra
Re: Rear brake pads
« Reply #5 on: 11 March 2018, 19:10:45 »
The genuine rear brake pads listed by Enceladus above come with fitting kit - springs and pins, probably the smaller size, I'll let you know. Also on the same site others list fitting kits for the 2.2 and the 3.2, which must be the bigger ones for aerated discs.
Re: Rear brake pads
« Reply #6 on: 11 March 2018, 20:29:14 »
They are the smaller pins/springs for non vented.  But the pads are the same.
I buy mine from this seller (and I get through a fair few ;D)
    • Zafira Tourer & BMW 435i
Re: Rear brake pads
« Reply #7 on: 11 March 2018, 20:39:07 »
I checked rear pads when giving 3.2 a wash today, I popped new ones on about 3 years ago. Still plenty of meat on them.
Re: Rear brake pads
« Reply #8 on: 11 March 2018, 20:42:54 »
You don't make much use of TC, do you ;D
  • Online Online
  • Chatham, Kent
  • Rover Metro 1.8VVC
    • 3.0l Elite estate
Re: Rear brake pads
« Reply #9 on: 11 March 2018, 21:26:27 »
Mine were fitted 6 years ago. The problem was one of them was stuck in the caliper, with what looked like cement dust(there was other evidence of that). This caused the inner friction material to come unstuck, and the outer pad to wear out. The disc is knackered. Rather frustrating, as there's several years use left in the other side. Once I'd cleaned all the crud out with the saw blade on my multi-tool, the old backing plate worked as it should. I was briefly tempted to just fit one new disc with the pair of pads I didn't use. But that sort of hackery isn't worth the £20 odd that I'd save.
New POD
  • Miseryside
    • NEED MV6
Re: Rear brake pads
« Reply #10 on: 11 March 2018, 21:51:17 »
I managed to find the pins and clips.  I kept getting sent short one's from so called brake specialists.
Re: Rear brake pads
« Reply #11 on: 11 March 2018, 23:11:25 »
Only flashes occasionally in winter, my Kumho's stick well.... Ish.
Picked cement dust up from the road? Maybe worth blast with pressure washer every so often then, I'll make sure mine are clean
terry paget
    • 3 Astras 2 Vectra
Re: Rear brake pads
« Reply #12 on: 14 March 2018, 14:07:13 »
Pads arrived today. Pin length is 2.7/8", 73mm, retaining spring 2.1/8", 47mm wide. Without dismantling a brake to cheack, it looks like the vented disc size. Pic follows. What a joy it is to own a mass produced car with cheap parts readily available!
terry paget
    • 3 Astras 2 Vectra
Re: Rear brake pads
« Reply #13 on: 14 March 2018, 14:10:36 »
Woops, here's the pic.
Re: Rear brake pads
« Reply #14 on: 14 March 2018, 18:03:29 »
Looking at springs, I'd say non vented, but its been a while since I've had one apart (but judging by the noises, it won't be long!!)
Page created in 0.045 seconds with 21 queries.
