Author Topic: Good place to pick up 12V IGN under hood  (Read 961 times)
Jan Suhr
  • Nyköping, Sweden
    • 2 Omega Caravans 3.2 V6
Re: Good place to pick up 12V IGN under hood
« Reply #15 on: 21 March 2018, 09:59:38 »
Thanks, I'll try that.  :y
Will post some pictures on how I did it.
This is the one I'm doing it for.
http://www.omegaowners.com/forum/index.php?topic=141164.msg1831453#msg1831453
The ones sold new in Sweden had the low beams turn on as running lights, there is a special wire loom for the Scandinavian Omegas.
This German one don't have anything like that and you have to turn on the lights manually every time you go out which is a thing you always forget. It at least beeps if you don't turn them off when you're done driving. :)
Jan Suhr
Stockholm, Sweden
www.protouring.se
Jan Suhr
  • Nyköping, Sweden
« Reply #16 on: 21 March 2018, 10:32:06 »
Just to be sure, I found this showing the relays in the relay box, but it is for a X25XE and X30XE  V6 and mine is a X32XE, might not be much difference but just to be sure.
From the above I conclude that K60 should be the green relay to the left, is that correct?
Mine don't have the headlight washers so no K97 here
Thanks
Jan Suhr
Stockholm, Sweden
www.protouring.se
    • 3.2 MV6 (LPG), Westfield
« Reply #17 on: 21 March 2018, 11:30:31 »
Right.. The purple connector in the centre of your picture.. immediately above the right hand green relay. That's the fan system test connector. The black wire to pin 3 of that is an ignition switched 12V feed. K60, the air con relay I mentioned as another possible place to tap into the switched feed, is the blue relay to the left of the two green ones. :y
« Reply #18 on: 21 March 2018, 16:42:42 »
The white, aircon, relay also has asn ignition feed... recently used to feed a supercharger coolant pump... 8) that car doesn't currently have aircon...
Jan Suhr
  • Nyköping, Sweden
« Reply #19 on: 24 March 2018, 07:44:00 »
Here is some pictures of how I did it.
I picked up the feed to the running lights as per the suggestion from Kevin Wood on the purple/pink connector and the relay needed a ground and I used that as well on this connector. Very tight space to work in and the wires don't have much play in them so the soldering don't look well. :-[
The black cable sheet with a blue and two black wires are going to the relay and down to the fog lights with my new cables.
Then I needed to hook up somewhere for the fed to the parking lights, when that goes hot it will turn of the running lights. The left side connection to the front lights was is very close and was easy to access. I had removed the left light to easier reach the cables to the fog lights. The parking light cable is gray and black. More space here for prettier solderings  :)
The feed to down to the fog lights was cut and connected back to the relay.
Here is how it now looks in the relay box with one more relay.
Jan Suhr
Stockholm, Sweden
www.protouring.se
« Reply #20 on: 24 March 2018, 09:22:44 »
Tidy job :y
Page created in 0.113 seconds with 21 queries.
