Author Topic: Any linux experts?  (Read 5382 times)
Re: Any linux experts?
« Reply #15 on: 31 March 2018, 10:56:20 »
Did I mention Perl is old and shit, and a complete mess?  Are you really sure you want to use a Perl app? ;)
Try libio-aio-perl
There are so few apps out there for what I want, that are free and self hosted, that I don't really have a huge choice. Plus it's only a bit of fun, nothing serious,
Tried your suggestions:
root@:~# apt install libio-aio-perl
Reading package lists... Done
Building dependency tree
Reading state information... Done
libio-aio-perl is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
root@:~# apt install libanyevent-perl
libanyevent-perl is already the newest version.
root@:~#
I still get:
Can't locate AnyEvent/AIO.pm in @INC (you may need to install the AnyEvent::AIO module)
« Reply #16 on: 31 March 2018, 11:25:01 »
libio-aio-perl is Debian's packaged AnyEvent AIO module.
Do you have aio.pm on the drive anywhere?  (find / -name "aio.pm"). If so, add its location to perl's inc, or softlink it from an area that is in Perl's inc.
« Reply #17 on: 31 March 2018, 11:29:34 »
I managed to find it using this wildcard: # find / -name "AIO*"
Results as follows:
/usr/lib/x86_64-linux-gnu/perl5/5.20/auto/IO/AIO
/usr/lib/x86_64-linux-gnu/perl5/5.20/auto/IO/AIO/AIO.so
/usr/lib/x86_64-linux-gnu/perl5/5.20/IO/AIO.pm
  • Auckland
    • Mazda MPV
« Reply #18 on: 31 March 2018, 12:32:09 »
Is this a permissions issue?
The AIO module appears to be related to 'asynchronous io' which would have meant rs232 serial communications on an original IBM PC.
To work with serial comms on a debian system you need to be a member of the group that can access the hardware (IIRC the 'modem' group)
« Reply #19 on: 31 March 2018, 21:44:21 »
Would have to be permissions on AIO.pm itself rather than the serial port group, but worth checking the permissions on that file and that the user is in the modem group.
Other than that, I tend to avoid Perl if I can. I'll give AIO a try when I'm next sitting at a suitable Debian machine.
« Reply #20 on: 31 March 2018, 21:49:26 »
Given that I installed (and attempting to run) as root, id be surprised if permissions?
« Reply #21 on: 31 March 2018, 21:54:20 »
Depends. The Perl interpreter might run under its own user.
Sounds more likely that it can't find the file, though. Is the source referencing an explicit path that's different in Debian to wherever the software originated?
