Author Topic: Wanted - 2.6v6 Timing belt kit  (Read 927 times)
Dr_Syn
  • Atherton
    • 2001 Omega 2.6CDX Auto
« on: 11 April 2018, 21:25:45 »
Hi, anyone have a timing belt kit for a 2.6?  Engine number 08541523.
Failing that, can anyone direct me to a cheap supplier?
Thanks.
biggriffin
  • huntingdon, Hoof'land
    • Vectra in a posh frock.
Hoof'land storeman..
Rwd-less..
Dr_Syn
  • Atherton
biggriffin
Re: Wanted - 2.6v6 Timing belt kit
« Reply #3 on: 12 April 2018, 07:59:37 »
Use your back plate.
Rwd-less..
deviator
  • Chesterfield
« Reply #4 on: 12 April 2018, 08:47:01 »
The threads on those bolts suggest this may have been fitted.
biggriffin
« Reply #5 on: 12 April 2018, 10:45:44 »
Ask the seller, it does say new, ..
Rwd-less..
Dr_Syn
  • Atherton
« Reply #6 on: 12 April 2018, 20:17:25 »
Well thanks to biggriffins advice about swapping the new tensioners onto my existing backplate, I've just ordered one of these:
https://www.ebay.co.uk/itm/222619968296
I thought I'd share as it seems to be a damn good price!
biggriffin
« Reply #7 on: 12 April 2018, 21:02:44 »
There's a tensioner pulley missing from that kit.
Rwd-less..
biggriffin
« Reply #8 on: 12 April 2018, 21:04:48 »
Also weren't these the kits that people we're buying g two off, because off the missing tensioner,and it was a cheaper way to get a kit....
Rwd-less..
Dr_Syn
  • Atherton
« Reply #9 on: 12 April 2018, 21:15:21 »
Bugger, I'm not having much luck lately :(
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
« Reply #10 on: 12 April 2018, 21:29:12 »
I had one of those AC Delco kits fitted by the brilliant James (V6CDX) about 6 weeks ago and it was just fine - he would NEVER fit rubbish!  :y 8)
Ron.
Dr_Syn
  • Atherton
« Reply #11 on: 12 April 2018, 21:34:26 »
Ron.
Was the kit complete or was there a pulley missing?
I've found another cheap kit, but this one doesn't show the bolts in the picture:
https://www.ebay.co.uk/itm/TIMING-BELT-KIT-QH-QBK337-VAUXHALL-SAAB-900-9000/392009367973?fits=Car+Make%3AVauxhall%7CModel%3AOmega%7CCars+Year%3A2001%7CPlat_Gen%3AB%7CCars+Type%3A2.6+V6%7CVariant%3AB+%5B1994-2004%5D+Saloon&epid=1634252412&hash=item5b459441a5:g:3P0AAOSwrLRavKzq
biggriffin
« Reply #12 on: 12 April 2018, 21:55:15 »
I'll say it, and get abuse.
Re-use the bolts you have, if there aren't any in that kit.
Rwd-less..
Bigron
  • Witham, Essex
« Reply #13 on: 12 April 2018, 22:18:48 »
Ron.
I don't know - James was so quick, blink and you miss it!  ;D
Ron.
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
« Reply #14 on: 13 April 2018, 13:54:49 »
Ron.
yes that kit will be fine but you do need two kits (unless you can find another pulley cheap but not usually) the power pulley is fixed on a 2.6 but an adjustable one can be used no problem. 40 for the lot is good even if you do end up with parts left over !
Page created in 0.115 seconds with 22 queries.
