Author Topic: power steering enquiry  (Read 411 times)
raywilb
  • york
    • 2.2dth gtx estate
« on: 25 April 2018, 21:40:18 »
about to have power steering pump changed in the morning. has anybody any idea on how much oil it will need.  :y :y
Re: power steering enquiry
« Reply #1 on: 25 April 2018, 22:37:04 »
Does Haynes or the owners manual not say ???
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #2 on: 25 April 2018, 22:54:37 »
I can't see it being more than 2 litres
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #3 on: 26 April 2018, 07:41:45 »
Only Haynes I have is for the pfl/mfl cars,but would suppose steering system stayed the same in which case Haynes give a figure of 1.3 litres.
« Reply #4 on: 26 April 2018, 08:43:46 »
Pump and steering gear fundamentally the same across the range, so it's probably a fair estimate  :y
Chazza12
  • south yorkshire
    • 1996 2.0 16v CD estate
« Reply #5 on: 26 April 2018, 10:10:08 »
i know there is a different size of power steering coolers, between the no tow bar and towbar fitted. as one for towbar seams to be wider. and 3 fins. had it changed on mine at the garage. 70 for new one.
« Reply #6 on: 26 April 2018, 12:16:24 »
Adds about 2" of 5/16 pipe ::)
Migv6
  • Webs End.
    • 3.2 Elite & Merc 190D.
« Reply #7 on: 26 April 2018, 19:06:51 »
Could be Albsiemers, but where is the PAS cooler ?  Don't remember ever encountering such a thing.  ???
Wish I didn't know now, what I didn't know then.
Dr_Syn
  • Atherton
    • 2001 Omega 2.6CDX Auto
« Reply #8 on: 26 April 2018, 19:15:13 »
I think the cooling is achieved by the pipes running across the front of the car infront of the radiator, I certainly didn't find a discrete oil cooler when I was changing my PAS pipes.
It took me less than a litre to refill the system, btw.
BazaJT
« Reply #9 on: 26 April 2018, 19:45:23 »
Yes I'd guess that the 1.3L figure is for a totally empty system to full.How much you'd lose changing the pump I don't know as I've never had to do one.
« Reply #10 on: 26 April 2018, 20:13:55 »
This...
It's no more complicated than it needs to be, although it can render the system prone to leaking from corrosion...
Page created in 0.16 seconds with 21 queries.
