Author Topic: Aircon fill valve problem  (Read 823 times)
GrayUK
  • Dunstable
« on: 04 May 2018, 19:05:44 »
Hi all,
I have a Y reg Omega estate 2.2.
My aircon is leaking, it passes the leak test on the machine but once disconnected, the gas goes in a few hours.
Very frustrating  :'(
To me the prime suspect is the fill valve.
Can someone point me in the right direction please for a new valve, and maybe how to fit it?
Thanks in advance. :y
    • R320 TDM850 SmartRoadster
Re: Aircon fill valve problem
« Reply #1 on: 04 May 2018, 19:16:57 »
Have look through this ..... http://www.omegaowners.com/forum/index.php?topic=142389.0;all ..... and the links within it. Should tell you all you need  :y
Migv6
  • Webs End.
    • 3.2 Elite & Merc 190D.
« Reply #2 on: 04 May 2018, 19:20:05 »
I ordered one today from my local dealer. Cost just over a fiver. Part number 13277003.  :y
Wish I didn't know now, what I didn't know then.
GrayUK
  • Dunstable
« Reply #3 on: 04 May 2018, 19:42:34 »
Many thanks
Was that the high pres. valve for a 2.2?
Migv6
  • Webs End.
« Reply #4 on: 04 May 2018, 20:20:35 »
High pressure valve yes, but for a 3.2. I would imagine the A/C parts are the same across the range though.
  • Millennium Man
    • The missus mad
« Reply #5 on: 05 May 2018, 08:02:51 »
Presumably they put dye in it on last fill, so worth looking for it, around the valves and the condenser in particular, then you will know before you pay for another refill.
I don't tolerate bickering, and I'm always grumpy.
And Lizzie Zoom says I'm a heartless bastid...and she's absolutely correct!
Migv6
  • Webs End.
« Reply #6 on: 05 May 2018, 08:51:06 »
I have signs of dye around the valves on mine, and the condenser is new, so I'm hoping replacing the valves will cure any leaks.
Just need to track down an elusive mate, who does a good job of A/C recharging for around 25.
GrayUK
  • Dunstable
« Reply #7 on: 05 May 2018, 17:58:07 »
Thanks for all your input. The airocn is not working again, and when i removed the dust cover , i heard a hiss with bubbles coming from the  valve.
You can clearly see the dye. The valve is f##ked !
Can i just remove the who body of the valve? or do you have to remove the core?
How do i post pictures on here?
« Last Edit: 05 May 2018, 18:02:59 by GrayUK »
« Reply #8 on: 05 May 2018, 19:05:14 »
16mm spanner on the valve whilst holding the hex welded to the pipe for the front valve, and a tyre valve core tool for the rear valve :y
GrayUK
  • Dunstable
« Reply #9 on: 05 May 2018, 19:07:48 »
Thanks, so just replace the whole body?
I have some pics but cant figure out how to post them!
« Reply #10 on: 05 May 2018, 19:14:09 »
No, just the core. In both cases :y
Buy both valves and how they are fitted will make sense ;) ;)
GrayUK
  • Dunstable
« Reply #11 on: 05 May 2018, 19:20:04 »
I tried to PM you the pictures i have but still cant do it! can you PM me your email address?
Thanks in advance
GrayUK
  • Dunstable
« Reply #12 on: 05 May 2018, 19:42:05 »
Hi, i had a look at that part number and it looks nothing like mine! mmmm ???
« Last Edit: 05 May 2018, 19:56:43 by GrayUK »
« Reply #13 on: 05 May 2018, 20:53:30 »
I will look at my 2.2 in the morning and see how they compare to the 3.2s  :y
Certainly with the V6s, you can buy the valves on their own, regardless of what the dealers try to tell you ::)
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
« Reply #14 on: 06 May 2018, 21:52:32 »
Does your HP valve look like this?
https://www.flickr.com/photos/53447058@N05/40782680065/in/dateposted-public/
and this should be a photo of your LP valve.
https://www.flickr.com/photos/53447058@N05/40962912514/in/dateposted-public/
Flick through the photos and you will find some others pics of the AC pipes.
Hope this helps.
Page created in 0.111 seconds with 22 queries.
