Author Topic: Washer pump  (Read 759 times)
alexw80
  • Bognor Regis
    • P reg Omega 2.0 CDX
Washer pump
« on: 08 May 2018, 10:42:01 »
Seems my washer pump is starting to give up, works intermittently with a very weak stream at times. I've found a replacement on eBay, I'm assuming this is the right part no.90508709. My question is how easy is it to replace, I've seen someone mention the steps needed to remove the bottle, is it the same or is there an easier method as I only need to change the pump?
Any help would be appreciated, thanx.
Bigron
  • Online Online
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
Re: Washer pump
« Reply #1 on: 08 May 2018, 11:26:09 »
If yours is the same as my FL V6, it's easy enough for even ME to do!
In my case, the pump was ok, just the filter blocked. Can you hear the pump running?
Ron.
alexw80
  • Bognor Regis
Re: Washer pump
« Reply #2 on: 08 May 2018, 11:34:39 »
I can hear the whirring noise when trying to spray the windscreen.
Bigron
  • Online Online
  • Witham, Essex
Re: Washer pump
« Reply #3 on: 08 May 2018, 11:41:32 »
Then you could be lucky and not have to buy a new pump motor. There are guides on here in the Maintenance section that are very good.
In my case, the hardest part was removing the grommet/filter that the motor spigot pushes into - and then getting it back in again! I have fat fingers, so you may well fare better.
Ron
alexw80
  • Bognor Regis
Re: Washer pump
« Reply #4 on: 08 May 2018, 13:22:09 »
Thanks for that, I'll have a look and see if that's the case. Found a new pump on eBay for less than 30 so it won't break the bank if it does need replacing.
    • R320 TDM850 SmartRoadster
Re: Washer pump
« Reply #5 on: 08 May 2018, 13:49:16 »
http://www.omegaowners.com/forum/index.php?topic=90616.0
This is what you're after. As per the guide, the filter does get clogged with gunge if no or little screen wash has been added.
Bigron
  • Online Online
  • Witham, Essex
Re: Washer pump
« Reply #6 on: 08 May 2018, 14:25:58 »
That's exactly the guide I meant, but couldn't find it quickly enough. I use plenty of screenwash, but TB doesn't approve of the ECP brand that I use - I'll let him tell you why.....
Ron.
  • Millennium Man
    • The missus mad
Re: Washer pump
« Reply #7 on: 08 May 2018, 18:22:47 »
Because its utter shite. Simples. You know it (now), I know it, my mums dog knows it...
I don't tolerate bickering, and I'm always grumpy.
And Lizzie Zoom says I'm a heartless bastid...and she's absolutely correct!
Bigron
  • Online Online
  • Witham, Essex
Re: Washer pump
« Reply #8 on: 08 May 2018, 18:35:43 »
I KNEW that you would provide the comprehensive technical reason, TB!  :y
Ron.
alexw80
  • Bognor Regis
Re: Washer pump
« Reply #9 on: 09 May 2018, 13:57:06 »
All sorted, the filter was to blame. Thanks for the advice, and saving me a few wasted s in the process.
  • Millennium Man
    • The missus mad
Re: Washer pump
« Reply #10 on: 09 May 2018, 19:17:12 »
Was it like a white, stringy, slime that had built up?  That's a sign that either your screenwash strength is too weak, or your screenwash is poor quality (or both ;D).
Dr_Syn
  • Atherton
    • 2001 Omega 2.6CDX Auto
Re: Washer pump
« Reply #11 on: 10 May 2018, 19:15:07 »
Or somebody has been doing something unspeakable with your washerbottle!  :o
alexw80
  • Bognor Regis
Re: Washer pump
« Reply #12 on: 11 May 2018, 00:26:06 »
Nope, nothing white found, just looked like dirt tbh. Screenwash is never too weak, always put plenty in, can't speak to the quality of it though, usually use the Halfords stuff, or Tesco if there's nothing else, but it's rare I use that.
  • Northampton
    • '16 Skoda, '06 BMW 650i
Re: Washer pump
« Reply #13 on: 11 May 2018, 08:32:27 »
You know you're not supposed to feed that stuff to animals, no matter how weak you think it is  :P
..and it went 'dugga dugga dugga dugga' no more.
Re: Washer pump
« Reply #14 on: 11 May 2018, 11:11:45 »
;D ;D ;D
The immediate thought through my head...
Page created in 0.117 seconds with 21 queries.
