Author Topic: What's this pfl MV6 worth?  (Read 1024 times)
biggriffin
  • huntingdon, Hoof'land
    • 02 3.2 mv6 estate.
Re: What's this pfl MV6 worth?
« Reply #15 on: 09 May 2018, 11:47:44 »
Well I did have it from nearly new back in early 2000, so got some pics of it looking nice and fresh then 😎.
Was a Vauxhall fleet car before me. It had 8400 miles on it when I got it and ( very sadly ) still got the purchase invoice from the Vauxhall dealer.
The rub is, hence the wife discussion, is I've already got a 1999 MV6 which is a one previous owner, full specced car with 113k on clock. Although it's suffering head gasket failure and awaiting attention presently and on SORN.
Not many chances to acquire one these days as numbers in their teens available. Guess if I buy it at least I can decide at a later date what to do.
Not taking the piss here BUT head gasket ??
What symptoms ?
I would be on the side of Tigers Gonads here  . .& cautious of diagnosing HG failure. There were some '99 cars suspect of HG failure as I understand it . . .but these were 2.5's , yours being a MV6 & therefore, I think a 3.0, &  HG failure on 3.0 engines is very very rare.   Oil cooler issue maybe ?
3.0L head gaskets do go,  doesn't give the same symptoms as oil cooler failure,   oil in header tank is oil cooler, head gaskets normally go at the back,and leak coolant.
Hoof'land storeman..
Omega is a barge not a dtm-touren-wagen
  • Millennium Man
    • The missus mad
« Reply #16 on: 09 May 2018, 17:57:55 »
Its actually the MY 1998 3.0l that are prone to HGF at the back of bank 2. Mine suffered it twice in the (long) time I had it.
As BG says, symptoms are losing coolant, no other issues.
I don't tolerate bickering, and I'm always grumpy.
And Lizzie Zoom says I'm a heartless bastid...and she's absolutely correct!
woolley11
  • York
    • 3.0 MV6 auto
« Reply #17 on: 09 May 2018, 22:01:39 »
Well I'm no mechanic but I've tinkered with cars over 30 years and can only conclude it's a hgf.
Symptoms of this HGF :
All coolant gone out of expansion tank
Emulsification in oil
Compression in o/s bank, 1st cylinder from front is reading 5 whilst rest are 10-12
Very rough running - fires up but stalls again
When it was running with coolant - steam/very visible emissions coming from exhaust
If someone has other diagnostics then very greatful to receive them.
Re the Champagne Omega - I'm thinking of going for it. I did like the car at the time very much and only sold it to go towards a deposit on a house.
I'll go in cheap and see where we go 👍
Alnico Blue
  • Costa del 'Saffend
    • 2001 2.6 CDX estate
« Reply #18 on: 10 May 2018, 07:39:18 »
Oh crikey  . . .looks like I have got that totally wrong then  :-[ :-[  was sure there was an issue with 2.5's of that era & HG failure . . . my age & memory having a part to play in this no doubt :-[ :-[ the word  "senile" comes to mind  ;D ;D
British made Celestion Alnico Blue = best sounding guitar speaker ever, sadly now made in China
tigers_gonads
  • Moaning Haddock Head
  • Kinston Upon Hull
    • 02 Mv6 Estate (lpg'd)
« Reply #19 on: 10 May 2018, 09:31:08 »
'dangle berries'
Sounds like you have that prognosis spot on sadly  :(
Please note, 95% of my posts are piss take or banter and should always be taken as so.
Please feel free to give it back in the same spirit.
  • Millennium Man
    • The missus mad
« Reply #20 on: 10 May 2018, 18:42:29 »
That's probably a different fault, not the HG.
The duff cylinder, i'd put a drop of oil in the cylinder, and re-measure.
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
« Reply #21 on: 10 May 2018, 19:34:08 »
When I had a head gasket go on a 1999 3l it was on the left bank rear cylinder, with low compression, but no oil in the coolant. As it got worse the water consumed increased and the cylinder would miss on tickover, but pickup at higher revs. With the hot engine running I could smell exhaust fumes coming from the expansion tank and the exhause always contained steam even on hot dry days with a hot engine. :o :o :o
  • Up North
    • Astra 2.0 diesel
« Reply #22 on: 10 May 2018, 19:39:42 »
I think you need to change you sig, Rods, oil is higher again today.  :)
If you are offended by anything I post, sorry. Just thought I'd get that in now.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #23 on: 10 May 2018, 20:03:30 »
If you get the engine hot (cooling system under pressure ) then whip out the plug ,you may get coolant out the plug hole
(confirming fire ring ,h/gasket failure )
oh ye...
probably be cold again by the time you get all the stuff out the way to get to the plug  ;D
low compression due to bore wash (water or fuel washing oil from round the rigs )  :-\
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #24 on: 10 May 2018, 20:31:56 »
Think that's why TB suggested oil in the cylinder and re-measure?Take compression reading,put some oil in cylinder and take reading again.If reading improves it's rings/bore wear if no improvement it's valves[least ways I believe that's the way it works]
woolley11
  • York
    • 3.0 MV6 auto
« Reply #25 on: 11 May 2018, 07:06:36 »
Well I guess I've got some more investigative work for the weekend !! 😳
  • Millennium Man
    • The missus mad
« Reply #26 on: 12 May 2018, 09:34:44 »
Was it a 98 MY though (what is last letter of VIN)
Tilbo
  • SOUTH LINCS.
    • Mercedes E 430& Terracan
« Reply #27 on: 20 May 2018, 06:56:20 »
Buy it restore it & keep it, simples.😀
Just cruising.When you are old you know everything,trouble is you have to deal with people who know nothing.
Page created in 0.111 seconds with 22 queries.
