Author Topic: Retrofit navi oem  (Read 1265 times)
  • Solihull
    • 3x 3.2 V6 Elite Saloons
Re: Retrofit navi oem
« Reply #15 on: 14 May 2018, 22:11:00 »
No Vectra-C screen is compatible. So don't even begin to investigate that, you'll waste your time.
Although the half CAN Vectra-C screen looks the same, its electronically very different.  The full CAN setup used a completely different Navi HU and screen, such as CD70, which is not compatible with Omegas.
Compatible screens were fitted to Astra-G and Vectra-B (and Omegas of course), compatible NCDC201x were fitted to Omegas, early Vectra-C and Corsas (usually only NCDC2011).
All components in the ring (NAV, CD (separate device, even though bolted to bottom of NAV), screen and Telematics (if used)) need to be in depaired mode.
I've seen that piece of shit o p c o m pair these up successfully, I've also seen it screw them up. I'd entrust to a tech2.
The screen and the unit ncdc must be from the same set?
Yes, unless they already unpaired with Tech II
    • 3.2 Elite & Zafira Tourer
« Reply #16 on: 14 May 2018, 22:16:23 »
Yes ideally, you can put CID/GID into “Delivery Mode” meaning you can pair to another NCDC, but it’s not reliable.
I like NCDC for factory feel look and integration with everything, but in my view it’s not worth hassle for navigation.
Got a VW, Audi, Skoda or Seat? I have full Diagnostic software VCDS to read and program your car. Need something enabling? Perhaps full diagnostic? Drop me a PM. Can diagnose in Camberley or Osterley Area.
olm
  • spain
    • 2.6 v6 sport estate
« Reply #17 on: 14 May 2018, 22:37:58 »
If I have the tech ll can buy the unit and screen separately?
olm
  • spain
« Reply #18 on: 14 May 2018, 22:39:41 »
Yes, I only do for the integrated look, I love this
zirk
  • Online Online
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #19 on: 15 May 2018, 01:34:32 »
Yes, I told you this 3 days ago -
Vectra C set up is not compatible, your need a NCDC (Bose configured) and a Paired Screen from an Omega.
Yes and No, only if they are in Delivery Mode, ie, they have been De Paired, and you have the Audio Pass Security Codes to Re Pair them.
All the above has been answered in your Post, you need to Re Read the replies, its all good info and will stop you going around in circles.  ;)
olm
  • spain
« Reply #20 on: 10 June 2018, 13:59:57 »
Another question, do I need the wiring from the unit and screen too? I see a unit and screen but not have the wiring
« Reply #21 on: 10 June 2018, 17:10:19 »
Where in Spain are you?
olm
  • spain
« Reply #22 on: 10 June 2018, 22:10:16 »
No, internet
  • Millennium Man
    • The missus mad
« Reply #23 on: 11 June 2018, 12:58:22 »
Depends what screen/HU are currently fitted. It is likely you will need to make an adapter due to slight differences between CCR2006 and NCDC201x looms.
I don't tolerate bickering, and I'm always grumpy.
And Lizzie Zoom says I'm a heartless bastid...and she's absolutely correct!
olm
  • spain
« Reply #24 on: 11 June 2018, 13:00:47 »
I have CCRT2008
« Reply #25 on: 11 June 2018, 14:22:05 »
Same... Need to switch various wires. Also need the RGB cable to connect the video aspect...
When I asked where you are, it was for the purposes of assistance...
olm
  • spain
« Reply #26 on: 11 June 2018, 15:53:37 »
Ahh, ok, sorry,  I'm ciudad real, are you live in spain?
« Last Edit: 11 June 2018, 15:57:17 by olm »
« Reply #27 on: 11 June 2018, 20:11:26 »
Sadly not, am currently in GC and would happily have assisted you if you were on the island :y
Page created in 0.109 seconds with 21 queries.
