Pages: [1] 2 3 4 5 6 7   Go Down
Author Topic: Unusual one with the Zaf this morning  (Read 2383 times)
    • 3.2 MV6 Est, E250 Est
« on: 14 May 2018, 07:52:17 »
Unusually by car was on the drive, so needed to reverse out....
Was 2.5 oC should it be of relavance.
Clutch felt a little strange, cant be more specific really.
Car stalled halfway out, and I couldnt get it out of reverse to restart it, seemed seized in gear.
Got it out, restarted it, moved it some more, and couldnt get it out of gear to go forwards.
Turned ignition off, got it out of gear, started it again, into first and off it went no more issues.
Tested reverse again once I got to work, and it felt a little rough, but in and out a few times and was fine.
Confused!
Auto Addict
  • North Birmingham
  • Oil burner
    • MB C-class Estate
Re: Unusual one with the Zaf this morning
« Reply #1 on: 14 May 2018, 08:32:56 »
Read the codes? :)
Merc lover
« Reply #2 on: 14 May 2018, 08:45:52 »
Not yet.....but will later.
tigers_gonads
  • Moaning Haddock Head
  • Kinston Upon Hull
    • 02 Mv6 Estate (lpg'd)
« Reply #3 on: 14 May 2018, 09:36:51 »
Manual or slushbox ?
Please note, 95% of my posts are piss take or banter and should always be taken as so.
Please feel free to give it back in the same spirit.
« Reply #4 on: 14 May 2018, 09:48:16 »
Manual.
Fuse 19
« Reply #5 on: 14 May 2018, 09:57:22 »
Oil level ok?
« Reply #6 on: 14 May 2018, 10:06:23 »
Oil?  Engine or gearbox?
tigers_gonads
  • Kinston Upon Hull
« Reply #7 on: 14 May 2018, 10:33:39 »
Brake fluid  ;)
Have you been playing with the brakes ?
Sounds to me like you have a little air in the clutch slave  :-\
Auto Addict
  • North Birmingham
  • Oil burner
    • MB C-class Estate
« Reply #8 on: 14 May 2018, 10:44:41 »
Gearbox I would think.
Reading your post again, my first point of call would be gearbox oil.
« Last Edit: 14 May 2018, 10:50:43 by Auto Addict »
Merc lover
« Reply #9 on: 14 May 2018, 17:23:53 »
Sticking slave :-\
How is the brake fluid level? Any fluid loss noticed?
This could be under the carpet rather than outside...
Also, possible to miss a gear if rushing... you may have got reverse without quite disengaging a forward gear (if left in gear when parked). Bringing your foot slowly off the clutch at idle in this case would cause the stall, and the torque through the box would effectively lock it temporarily... Restart and neutral would reset the status quo.
Gear linkage adjustment or wear would probably be my first port of call if the clutch is otherwise functioning normally...
Gearbox wear is another possibility if it's been driven hard... Not as durable as the Vectra C box.
« Last Edit: 14 May 2018, 17:39:29 by Doctor Gollum »
  • Up North
    • Astra 2.0 diesel
« Reply #10 on: 14 May 2018, 18:27:09 »
So...in conclusion...it could be anything from knackered gearbox to alien interference.  ;D
If you are offended by anything I post, sorry. Just thought I'd get that in now.
« Reply #11 on: 15 May 2018, 07:32:56 »
Well it was fine all the way home, fine yesterday evening, only an EGR code flagged.
Was fine this morning....
until 2 miles from work anyway when I lost my clutch in the centre of Crewe :(
Pushed it to safety, then got a colleague to tow me to work.
Now stranded here :(
    • R320 TDM850 SmartRoadster
« Reply #12 on: 15 May 2018, 08:09:10 »
Release bearing?
I replaced the gearbox on an Astra G I had ..... not I job I'd want to do too often, but do-able on a drive
« Reply #13 on: 15 May 2018, 08:10:20 »
No idea, clutch pedal has zero resistance, goes straight to the floor without doing anything
« Reply #14 on: 15 May 2018, 08:13:21 »
Any change in fluid level?  I assume it's the usual Vauxhall set up where by the brakes share the reservoir with the clutch  :-\
Pages: [1] 2 3 4 5 6 7   Go Up
Page created in 0.11 seconds with 22 queries.
