Pages: 1 2 3 4 5 6 [7]   Go Down
Author Topic: Unusual one with the Zaf this morning  (Read 2671 times)
Re: Unusual one with the Zaf this morning
« Reply #90 on: 16 May 2018, 21:21:07 »
Right.  So what shouldI be looking at.
1st clutch & Dmf did 80000 and 6 years
this one has 56000 and 3 years under its belt.
Should I be just getting this slave done, or given the work involved, everything while its in bits?
« Reply #91 on: 16 May 2018, 21:22:15 »
To add insult to injury I dropped the battery as I went to put it back in.  Acid all over the drive now and more expense.
If it wasnt for bad luck, I'd have no luck at all   :'( :'( :'(
« Reply #92 on: 16 May 2018, 21:49:17 »
Want to buy an A Class  :D
Do the lot :y
  • Up North
    • Astra 2.0 diesel
« Reply #93 on: 16 May 2018, 22:38:02 »
Look on the bright side, it never landed on your foot.
If you are offended by anything I post, sorry. Just thought I'd get that in now.
« Reply #94 on: 17 May 2018, 16:06:28 »
Connected up my spare battery after charging it.
I have have a pedal that feels like a clutch pedal, but it doesnt work too well!
Got it into reverse and out the drive fine, round the corner fine, out of gear at junction and stall!  struggle to get it out of gear,
restart, into reverse move a bit, stall, and stuck in reverse again.
cant restart it in neutral without it stalling, so into first to start and move together, out the road into a big enough circle to drive back in, and back on the drive!
Can see fluid on the road where I was attempting manoeuvres
Not gonna move it again until its going in for repair, with someone to tow if needs be.
fluid level is ok, but its clearly still loosing, and nowt to see in the bay.
« Reply #95 on: 18 May 2018, 20:10:52 »
Booked in for next week.
Just got to try a Ďfuní drive to get it there. Iíll pick a quiet time!
Auto Addict
  • North Birmingham
  • Oil burner
    • MB C-class Estate
« Reply #96 on: 18 May 2018, 20:16:20 »
Whose doing it?
Merc lover
« Reply #97 on: 18 May 2018, 21:16:10 »
The usual local garage I use for MOT's etc
Given its virtually undrivable, im fairly limited in where I can get it.
Auto Addict
  • North Birmingham
  • Oil burner
    • MB C-class Estate
« Reply #98 on: 19 May 2018, 06:36:16 »
Merc lover
Pages: 1 2 3 4 5 6 [7]   Go Up
Page created in 0.135 seconds with 21 queries.
