Author Topic: key pcb  (Read 292 times)
andypfc
  • havant
    • omega elite 3.2
key pcb
« on: 15 May 2018, 13:55:03 »
hi. i have bought a remote pcb as a spare and  have the original transponder. how do i marry the apparently blank pcb to the car which is a 02 omega 3.2 elite. any help would be appreciated. i do have "My Naff Code Reader" china clone if that helps
Re: key pcb
« Reply #1 on: 15 May 2018, 15:36:07 »
Don't use that. Not for key programming.
Instead pm Kevin Wood, he's about 40 mins from you and does exactly what you require doing for a sensible fee using genuine Tech 2.
Linky to his prices at bottom of his profile signature  :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: key pcb
« Reply #2 on: 15 May 2018, 16:21:24 »
What He said, /\ /\
Unless your really competent at using the Popcon, which by the way isnt really discussable on this Forum, your probably end up bricking something.
Your also need the Car Pass Code for the Car as well. The Transponder Chip, is ready to go, but you probably already knew that.
    • 3.2 MV6 (LPG), Westfield
Re: key pcb
« Reply #3 on: 15 May 2018, 16:37:04 »
Yep, happy to help, as above. Beware that there are at least 3 different types of PCB within identical looking remotes, though. It would be worth checking that the new one is identical to the one in your existing remote to save a wasted journey. :y
Page created in 0.104 seconds with 21 queries.
