Author Topic: Dash display  (Read 315 times)
Malcolm_D
  • York
  • It shines!
Dash display
« on: 16 May 2018, 07:28:53 »
The computer display on my 2.6 Elite has gone nuts! Randomly will start flashing, lots of colourful strips appear, sometimes it just goes grey. If I give the dash a thump it will sometimes return to normal - loose connection?
Strangely enough the display in my 55 plate Sorento does the same!
Any ideas / suggestions?
Chazza12
  • south yorkshire
    • 1996 2.0 16v CD estate
Re: Dash display
« Reply #1 on: 16 May 2018, 08:07:09 »
The LCD screen needs resetting on it's connection. Or the LCD ribbin has a bad connection. Switch cleaner or liquid flux with a old tooth brush should clean the ribbon without damaging it. And refit the screen. Even sometimes heating the back with a hair dryer can fix them but don't hold it on for to long.
Alnico Blue
  • Costa del 'Saffend
    • 2001 2.6 CDX estate
Re: Dash display
« Reply #2 on: 16 May 2018, 09:03:15 »
Presuming this is a Colour screen ( as only CID's will show grey when faulty)
Common fault with CID screens . Comes on with age , sadly it wont improve , eventually from experience, banging on the dash will cease to re instate to norm .
I believe a new screen can be fitted but don't think the screen is the problem here.
I did have one repaired once & as I recall it was dry /broken joints where the ribbon cable was joined / soldered to the PCB. This is micro soldering so quite specialised. But the repair was successful although not cheap  :'( :'(
Other Oofers with more knowledge of these CID failures  will be able to add to this.
HTH  :y
« Last Edit: 16 May 2018, 09:10:47 by Alnico Blue »
British made Celestion Alnico Blue = best sounding guitar speaker ever, sadly now made in China
  • Millennium Man
    • The missus mad
Re: Dash display
« Reply #3 on: 16 May 2018, 18:21:33 »
Its where the ribbon joins the lcd panel, and sadly not repairable (without very specialist equipment)
Only solution is a new panel (or if you have access to a tech2, a depaired replacement cid)
I don't tolerate bickering, and I'm always grumpy.
And Lizzie Zoom says I'm a heartless bastid...and she's absolutely correct!
Page created in 0.106 seconds with 22 queries.
