Author Topic: Removing a seized circlip  (Read 868 times)
Re: Removing a seized circlip
« Reply #15 on: 24 May 2018, 10:02:15 »
But have you lost an eye yet? ;)
I got the (much smaller) circlips moving by levering one end out and then using a screwdriver to 'walk' the rest of it out far enough that it could come flying out like some kind of tiny un-guided missile.. (and then we had to weld bolts on to the bearings to get those out ;D)
If I could get any movement on it then Iíd try that!
tigers_gonads
  • Moaning Haddock Head
  • Kinston Upon Hull
    • 02 Mv6 Estate (lpg'd)
« Reply #16 on: 24 May 2018, 10:11:49 »
If you have a fine cutter, can you cut across the clip 180 degrees so its in 2 parts ?
That way, the spring tension should work in your favour and it should prise out easier  :y
You will need a new clip mind you  :y :D
Please note, 95% of my posts are piss take or banter and should always be taken as so.
Please feel free to give it back in the same spirit.
« Reply #17 on: 24 May 2018, 10:29:35 »
Yeah... Not enough space to get through it but itís on the list of possibilities... Heat is next on the list ::)
tigers_gonads
  • Kinston Upon Hull
« Reply #18 on: 24 May 2018, 11:15:05 »
What  :o
A gallon of unleaded and a match ?   :D
Gaffers
  • Online Online
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #19 on: 24 May 2018, 11:47:17 »
What  :o
That's the best cure for any french motor car.
« Reply #20 on: 24 May 2018, 23:37:26 »
What  :o
Nah, thatís a waste of unleaded... Have you seen the price lately? ???
Iíll use contaminated fuel instead! ::) :D
« Reply #21 on: 25 May 2018, 10:00:31 »
Just an update... Resorted to a bit of heat in the end and it popped out fine... Wish Iíd Dug out the gas bottles earlier now ::) Although I suspect the overnight soaking helped too
Auto Addict
  • North Birmingham
  • Oil burner
    • MB C-class Estate
« Reply #22 on: 25 May 2018, 10:42:36 »
Merc lover
Page created in 0.107 seconds with 22 queries.
