Author Topic: Air con low pressure pipe hot  (Read 990 times)
grifter
  • Paisley, Scotland
  • Omega 2.6 owner
    • Omega 2.6
« on: 24 May 2018, 22:22:37 »
Hi, i've got a good pressure in my AC now and compressor kicked in but 1) no cool air and 2) the low pressure pipe is quite warm to touch, the HP pipe is burning, I know the HP gets hot but I don't think it should be burning hot and the LP should be cold. Any thoughts?
DrAndyB
  • Neston / Cheshire
    • 2.5 V6 CDX Manual (MFL)
Re: Air con low pressure pipe hot
« Reply #1 on: 27 May 2018, 18:30:42 »
Take it to be re-gassed.  Note how much comes out, as I think from memory there is should a 950g of R134a !!
Worth getting a new HP valve and LP core and get them to pop them on before filling  :y
At least you will know what is in there is what it should be.
Also, is the compressor spinning ? Should be easy to eyeball it  ;)
biggriffin
  • huntingdon, Hoof'land
    • 02 3.2 mv6 estate.
« Reply #2 on: 27 May 2018, 19:33:15 »
Compressor only spins if enough gas,is present, if it detects either to much or to little, won't engage.
Hoof'land storeman..
Omega is a barge not a dtm-touren-wagen
DrAndyB
  • Neston / Cheshire
« Reply #3 on: 27 May 2018, 20:15:05 »
grifter
  • Paisley, Scotland
  • Omega 2.6 owner
    • Omega 2.6
« Reply #4 on: 27 May 2018, 22:01:38 »
Yep was spinning. What do you mean LP core?
biggriffin
« Reply #5 on: 27 May 2018, 22:18:24 »
Looking into bonnet from front of car, LP valve is the one near bulkhead,(std tyre core),, HP is just the one at front above fan. (GMpart)
abokayed
  • Amman
    • Omega Elegance 2003
« Reply #6 on: 27 May 2018, 23:26:45 »
Hey Sir! , from what you have mentioned i can tell that you have a problem in the AC System , not sure where it comes from but i tell you from what i know , because i had an experience with this matter before , so the thing is as follows , the HP Line should be hot , i mean like real hot that is a normal thing , but the low pressure pipe should be significantly COLD to touch , when everything works as it should be make sure of the following as a checklist
- make sure the condenser fins are not clogged with Dust , particles and insects , make sure to clean it
- Make sure that the condenser fan kicks in at the right speed when you turn the AC system usually at the high speed but it could run in low speed
  depending on the weather and traffic ....etc
- the amount of R-134 (Refrigerant Gas) is the right amount as mentioned from the car manufacturer which i think is (950 gram)
- there is no water moisture in the system - this can be solved by taking it to AC specialist to suck all the moisture out and vacuuming the system and refilling it with the right amount of R-134 (Refrigerant Gas)
- the compressor is not working efficiently (could be a bad compressor) - it is recommended to change the Receiver Dryer when you change the compressor
- Faulty Expansion Valve
- Clogged condenser or evaporator
grifter
  • Paisley, Scotland
  • Omega 2.6 owner
    • Omega 2.6
« Reply #7 on: 28 May 2018, 07:30:37 »
Thanks i will get these checked, i know from experience hp pipe should be warm, think it was too hot almost to touch, which led me to believe one of the things or a combination were at fault, a blockage, poor circulation etc.
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
« Reply #8 on: 28 May 2018, 09:27:40 »
Your memory is correct. The label on mine says 950g.  :y
Andy A
  • Bristol UK
« Reply #9 on: 28 May 2018, 10:27:36 »
A couple photos and a part number for the HP valve.  :y This is from my 2.2 so your layout might be slightly different but the HP valve is identical.
Low pressure Valve (LP). Standard AC valve core or tyre valve core.
High Pressure valve (HP). P/N 13277003
abokayed
  • Amman
« Reply #10 on: 28 May 2018, 12:38:19 »
You are more than Welcome   :) , about the temperature of the HP line i know that it gets too hot and it is normal that way, i noticed this with 3 different cars , that you cant touch it from its heat. so from my side i think that is a normal thing , i could be wrong but i said this based on my experience with it from different cars
Thanks!
grifter
  • Paisley, Scotland
  • Omega 2.6 owner
    • Omega 2.6
« Reply #11 on: 28 May 2018, 13:45:43 »
Thanks!
I do know the lp pipe should be cold and gather condensation, and it definitely wasn't, lukewarm to touch.
abokayed
  • Amman
« Reply #12 on: 28 May 2018, 14:35:23 »
Thanks!
Yup That is Correct , that is the biggest indicator that ur AC System is not working properly
grifter
  • Paisley, Scotland
  • Omega 2.6 owner
    • Omega 2.6
« Reply #13 on: 03 July 2018, 13:48:14 »
Is it easy enough to access the condenser,  do I need to remove the fans only to get in to check it's clean?
« Reply #14 on: 03 July 2018, 13:54:00 »
You can, but you'll need to remove the radiator and condenser in order to remove the fans...
 ;D
Page created in 0.136 seconds with 22 queries.
