Author Topic: Ignition barrel replacement  (Read 828 times)
fudgee
« on: 02 June 2018, 06:55:33 »
Hi guys.
The ignition barrel on my 2.2 cd auto seized up completely after a week or so of just being very stiff.
I was tempted to try and repair it but decided to buy a brand new one from vauxhall as it was only 87 all in.
I removed the old one easily enough by pressing a 3 ml Allen key into the release hole but have now broken the replacement barrel.
When I was pushing the barrel into the ignition it just kept pushing itself back out. I couldn't get it to click in.
It would just pop out and the steering lock would pop on in an identical way to when I popped the old barrel out.
After about 6 attempts at pushing the new barrel in i noticed when I looked at it the little spring loaded flap on the barrel had snapped in half and the tiny spring inside was protruding.
So now I have to buy another one from vauxhall but before I do can anybody educate me as to what I was doing wrong?
I had to turn the key in the new barrel one turn to get it to slide in and once it was in it would let me turn it to position 2 so the dash lights would come on but wouldn't turn again to let me start the engine.
As soon as I released pressure it just popped back out and " ping " steering lock clicks back in which I kept having to release by pushing down on the little metal lever inside the ignition  :(
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
Re: Ignition barrel replacement
« Reply #1 on: 02 June 2018, 07:43:14 »
Have you had a look at Shackengs guide in the maintenance section to see if there's anything you missed?
  • Online Online
  • Chatham, Kent
  • Rover Metro 1.8VVC
    • 3.0l Elite estate
« Reply #2 on: 02 June 2018, 08:27:57 »
I hope that 87 barrel uses the same key as the rest of the car?
LINK
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #3 on: 02 June 2018, 08:33:12 »
LINK
even the 11 quid ones do if you take the tumblers out  ;D
and as Fudgee now has 2 broken ones to play with , he may as well play Chinese puzzle hunt the spring  :y
  • Online Online
  • Chatham, Kent
    • 3.0l Elite estate
« Reply #4 on: 02 June 2018, 10:29:10 »
LINK
The tumblers are the main wear parts; reusing them is crazy
fudgee
« Reply #5 on: 02 June 2018, 10:51:46 »
Nick W yes it takes the same key mate. I have the key code luckily
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #6 on: 02 June 2018, 10:57:49 »
LINK
there will be NO wear on the 87 tumblers , assuming it was made to the lock number (matching keys) , maybe the old spring loaded retainer  flap could be used on the new barrel  :-\
it's been a long time since i had a barrel in bits , it is a faf ,
especially if you have big fat sausage fingers like me  ;D
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #7 on: 02 June 2018, 11:58:35 »
I did similar and found that the ignition switch wasn't in the right position to receive the new barrel so having tried to force I cracked the same piec, long thin screwdriver helped reposition it
fudgee
« Reply #8 on: 02 June 2018, 13:01:01 »
Thanks Omegod.
When the steering lock kept kicking in I pressed it down with a screwdriver to take it back off.
Is adjusting the ignition switch a similar process and I'm assuming it's also deeper down inside then the steering lock lever?
  • Online Online
« Reply #9 on: 02 June 2018, 13:27:50 »
Key needs to be fitted and inner barrel turned to pos 2 iirc prior to installing the assembly back into the column :y
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #10 on: 02 June 2018, 19:38:04 »
No need to pay that sort of money, just get one from a scrapper and fit new tumblers to match your existing. They are pretty much the only bits that wear, (not counting accidental damage ::)). There is an excellent guide here for replacing the tumblers: http://www.omegaowners.com/forum/index.php?topic=90600.0
I have had replacement tumblers from here: https://www.nwkeys.co.uk/Product/discontinued-keying-kit-to-suit-vauxhall-h-y-laser-series-locks, I never registered, just found their number and rang them.:y
fudgee
« Reply #11 on: 04 June 2018, 19:50:31 »
Just a quick update and its both good and bad news. I managed to fit the replacement barrel i purchased from Vauxhall.
I just removed the ignition casing from the new part which of course has the broken retainer flap on it and put the casing from the old barrel on it which had nothing wrong with it.
Key turns fine and car starts fine but now the ignition barrel is not disengaging properly :(. When i remove the key the radio stays on, cant put the steering lock on, i can still operate the windows and because the ignition is still on i cant remotely lock it so i have to lock the car manually.
And of course i cant pop the boot :(
The ignition is operating like its still on position one but it allows me to remove the key which is a contradiction.
Its obviously something ive done wrong when refitting the new part.
Probably gonna call an auto locksmith out to take a look tbh as its a little over my head now
 :D
  • Online Online
« Reply #12 on: 04 June 2018, 20:06:01 »
Guessing you didn't read the guide beforehand  :-\
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #13 on: 04 June 2018, 20:36:01 »
try wd40 in the key hole via a straw
this happens on many vauxhalls
something sticks
or take it apart again and lube it all up
unless you have the electrical switch in the wrong position when inserting the barrel
sounds like your 89% there , why spend $100+ to finish the job getting an auto locksmith  :-\
fudgee
« Reply #14 on: 04 June 2018, 20:49:10 »
I did read it mate in fact i followed it to the letter.
Its a very good guide. You cant really put the barrel in at the wrong angle as it only goes in one way. If its turned slightly to much to the right or left it doesnt even go in halfway.
I have no doubt its me thats at fault as its a brand new part straight out of the packaging.
Page created in 0.145 seconds with 21 queries.
