Author Topic: Auto solenoid  (Read 659 times)
Migalot
  • London
    • Omega 2.6 2002
Auto solenoid
« on: 20 June 2018, 16:56:39 »
Irrespective of other issues concerning my crank sensor, I intend to have my auto box filter and ATF both renewed, as the car has done nearly 70k miles.
I thought it might be useful to have the 2/3 solenoid exchanged at the same time (should be straightforward once the sump is off).
Unfortunately, I can't source one. Sussex Auto Parts tell me it's a BMW 4L30E box and the part number is 24337537062. Everywhere I look it seems to be unavailable.
Any friendly advice warmly welcomed. :y
Re: Auto solenoid
« Reply #1 on: 20 June 2018, 17:06:08 »
Well, it's not a BMW box for a start :y
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Re: Auto solenoid
« Reply #2 on: 20 June 2018, 17:27:33 »
You can get them from here  :y
Stll be better to bin the box and put a AR35 into it  :y
« Last Edit: 20 June 2018, 17:33:14 by Steve B »
  • Chatham, Kent
  • Rover Metro 1.8VVC
    • 3.0l Elite estate
Re: Auto solenoid
« Reply #3 on: 20 June 2018, 17:31:49 »
BMW did use them, although they were bought from GM
And it is a 4L30
Migv6
  • Webs End.
    • 3.2 Elite & Merc 190D.
Re: Auto solenoid
« Reply #4 on: 20 June 2018, 17:55:06 »
I wouldn't bin a 70k box and fit an (possibly unkown) AR35 to a car which doesn't do many miles per year. Solenoid change sounds like a good idea to me.
Jpat rings a bell, istr they used to advertise gearbox spares on here, so sounds like a good place to try for the solenoid.  :y
It is indeed a GM L430 unit.  ;)
Wish I didn't know now, what I didn't know then.
Steve B
  • Leicestershire
Re: Auto solenoid
« Reply #5 on: 20 June 2018, 18:14:44 »
I did to a 2.2....but it was a known working ok box from a member on here.and i never looked back,and that box is still going strong today.....think jpat were not cheap on the valves..then its fluid out sump off roll pins out..swap valves hoping that you have sorted the problem of the thump into gear effect when going from 2-3....
Migalot
  • London
    • Omega 2.6 2002
Re: Auto solenoid
« Reply #6 on: 20 June 2018, 18:27:33 »
Much obliged, Steve. I'll give them a try!  :y
Migalot
  • London
    • Omega 2.6 2002
Re: Auto solenoid
« Reply #7 on: 20 June 2018, 18:33:25 »
I think you're right. I'll source from Jpat if poss.  :y
Odd that Sussex Auto Parts were adamant about it being a BMW box! ???
Migalot
  • London
    • Omega 2.6 2002
Re: Auto solenoid
« Reply #8 on: 20 June 2018, 18:41:25 »
Ordered a new filter but forgot to order the sump gasket. Doh!  :-[
Anyone got a part number, pretty please?
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Auto solenoid
« Reply #9 on: 20 June 2018, 18:46:44 »
Going to swap my fluid and filter
found this filter for 10 delivered
filter
and 10 lir of dexron 3 semi for 35 delivered
dex 3 clicky
and this instead of gasket @ 1.60
rtv seal
Migalot
  • London
    • Omega 2.6 2002
Re: Auto solenoid
« Reply #10 on: 20 June 2018, 18:57:59 »
filter
dex 3 clicky
rtv seal
Filter already ordered, but that Dexron deal looks good.  :y :y
Cheers, Dave!
I won't be doing the change myself, so I am not sure whether the garage would want to use the seal instead of the gasket. I would need to check with them.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Auto solenoid
« Reply #11 on: 20 June 2018, 19:09:41 »
There are 2 sump gaskets ,
a good garage would do it the way you asked them too
many on here recommend RTV instead of a gasket on the sumps  :y
Re: Auto solenoid
« Reply #12 on: 20 June 2018, 19:17:22 »
Many garages won't use customer supplied parts...
Migalot
  • London
    • Omega 2.6 2002
Re: Auto solenoid
« Reply #13 on: 20 June 2018, 19:21:20 »
OK, no probs, Dave. Cheers.  :y
I use a small local garage and they are friendly and accommodating they fitted my supplied wishbones the other week!
They offered to swap the solenoid if I provided the part (though no guarantees about outcome as they are not transmission specialists).
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Auto solenoid
« Reply #14 on: 20 June 2018, 19:37:02 »
Because they get a discount ,60 days to pay for parts and charge customer list price
I don't trust garages , do the work my-self ,with parts i supply and give myself the standard 10 second warranty  ;D
Page created in 0.117 seconds with 22 queries.
