Author Topic: New Router  (Read 200 times)
Sir Tigger QC
    • BMW 530d & 2 Fords
New Router
« on: 07 July 2018, 20:08:29 »
I've recently switched from Talk Talk to Plusnet and my new router has arrived.
I've been using an elderly Belkin router for yonks and intend to try the new one in a different place in the house.  The instructions recommend using the primary phone socket, but the one I want to use which is in the centre of the house is a secondary socket.
Does it make that much difference?  :-\
TIA!  :y
JC is not The Messiah, he's a very naughty boy!!
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
Re: New Router
« Reply #1 on: 07 July 2018, 20:17:49 »
If the secondary socket is taken off before any broadband/voice filters then probably, if not no as you won't have a broadband signal. I would suggest initially setting it up on the primary socket to get it working followed by a speed test and then trying it on secondary, if it works repeat the speed test to check the quality of the signal at the secondary socket.
  • Millennium Man
    • The missus mad
Re: New Router
« Reply #2 on: 08 July 2018, 09:19:11 »
Depends how your telephone wiring is done. And the quality of that wiring. And in the case of faults in the future, you will have to move the router to the NTE5 socket for diagnostics.
Why move it, is it for better Wifi coverage or because you need the cat5 there? There may be other options if required.
Remember the first 10 days are the training period, whereby a suitable profile is determined and put on the line, so try to keep things stable, else you may end up with a slower profile.
Also, any socket with a device plugged in needs a filter
I don't tolerate bickering, and I'm always grumpy.
And Lizzie Zoom says I'm a heartless bastid...and she's absolutely correct!
Page created in 0.092 seconds with 21 queries.
