Pages: 1 2 [3]  All   Go Down
Author Topic: Alarming clonking noise offside front  (Read 1307 times)
terry paget
  • Midsomer Norton Somerset
    • 5 omegas all petrol & man
Re: Alarming clonking noise offside front
« Reply #30 on: 09 July 2018, 20:42:31 »
As the car has recently passed the MOT, could you not carry on using it until you,re in a more robust state to do the job.? :-\
Yes I could, though the noise is a bit embarrassing, worrying too. The car passed MOT 78 miles ago, after a long struggle, see recent thread. Son Ben was using it, he complained of a noise and brought it to me for diagnosis and rectification. It seems unlikely that it would be a failed wishbone. The sound is more like a loose droplink, though it clearly comes from front right.
« Reply #31 on: 09 July 2018, 20:58:26 »
No need to make life so damn difficult ::)
Tighten the droplink nuts on both sides and plan for the wishbone change as that vertical bush is knackered regardless of how MoTd the car is.
    • 3.2 MV6 (LPG), Westfield
« Reply #32 on: 10 July 2018, 08:50:56 »
If that is a newish drop link, beware that it might have failed quickly. I had a pattern pair that failed inside a year. Meyle HD ones currently fitted seem better.
Also worth checking the ARB bushes, although they rarely seem to fail.
Brake calliper can rattle if the slide pins have dried out.
Wishbone bush doesn't look too clever but I've never had one bad enough to rattle. If you put a new wishbone on that'll also eliminate the ball joint, of course.
  • Chatham, Kent
  • Rover Metro 1.8VVC
    • 3.0l Elite estate
« Reply #33 on: 10 July 2018, 09:11:55 »
A badly worn strut can rattle and knock. My NSF one was so bad it had NO damping, and had worn through the hard chrome plating on the piston which I could rattle (by hand) in the bush. It's not the first time I've seen that, and is why replacing all of the wear components at the same time is recommended over doing them piecemeal.
terry paget
« Reply #34 on: 10 July 2018, 11:19:34 »
Rejoice! Fault traced and cured.
Following Doc G's suggestion above, it occurred to me that the drop links are joined by the anti roll bar, so a loose nut on the LH drop link might cause the RH link to clonk. And so it proved. The upper nut on the LH drop link was loose, I torqued it up, road tested car, clonk gone.
My thanks to all for advice. I regard it as mean and unhelpful of the car to clonk on the right when the fault was on the left, but there you go.
« Reply #35 on: 10 July 2018, 11:27:46 »
See, I can be helpful  ::)
  • Millennium Man
    • The missus mad
« Reply #36 on: 10 July 2018, 18:12:10 »
The noise is just like I have known before with loosely fitted drop links.
In which case its a loose droplink nut, or a knackered droplink. That droplink rattle is pretty distinctive and unique to droplinks.
I don't tolerate bickering, and I'm always grumpy.
And Lizzie Zoom says I'm a heartless bastid...and she's absolutely correct!
  • Millennium Man
    • The missus mad
« Reply #37 on: 10 July 2018, 18:12:34 »
Ah, teach me to post without reading all pages.
Glad its sorted :y
sg61
  • SW11
    • Omega Elite V6 Auto
« Reply #38 on: 12 July 2018, 12:45:15 »
Will keep an eye on these posts as I seem to have a similar clonk - although I have bigger problems to sort out first!
mandula
  • Finland
    • Opel Omega -03, Z22XE man
« Reply #39 on: 12 July 2018, 13:40:07 »
To rule drop links and anti-roll bar bushings out, just detach either one drop link and see if clonk noise is still there. If it's not, you have faulty drop link(s) and/or anti-roll bar bushing(s).
terry paget
« Reply #40 on: 12 July 2018, 16:09:54 »
Thank you; excellent tip.
And what was the clonk I was hearing?
It was the RH anti-roll bar end banging on the wishbone, when suddenly released as the loose LH drop link slipped.
Pages: 1 2 [3]  All   Go Up
Page created in 0.154 seconds with 22 queries.
