Author Topic: rapid tyre wear  (Read 333 times)
annihilator
  • Wirral
    • Elite,Tourer V6's
rapid tyre wear
« on: 09 July 2018, 10:35:48 »
I know our cars will eat tyres if the the geometry is not correct but does less than 4 months and 500 miles seem right for this  >:(
also noted what may be an age crack which might have contributed (tyre past it's best?)
and since shortly after MOT (hence mileage/time frame known) was done the abs fault occurred and as this also effects the steering could that accelerate the process.
John.
  • Chatham, Kent
  • Rover Metro 1.8VVC
    • 3.0l Elite estate
Re: rapid tyre wear
« Reply #1 on: 09 July 2018, 10:46:58 »
That's classic worn suspension/terrible alignment. More likely, both
 I bet it drives abominably too.
Re: rapid tyre wear
« Reply #2 on: 09 July 2018, 10:57:43 »
Badly set up/knackered bushes will do that in less than week.
annihilator
  • Wirral
    • Elite,Tourer V6's
Re: rapid tyre wear
« Reply #3 on: 09 July 2018, 11:45:57 »
no knocks from front end, Mot pass in April only advisories for rear donuts and setup not changed in 2 years of ownership .I suspect it knew I was thinking of a geometry check as i've got a nearly new set of michelins and wanted it doing before putting them on so no not bothered just seemed a bit rapid.
Drives very well to the shops and back. :-X
Temporarily replaced with a blast from the past  :D
« Last Edit: 09 July 2018, 11:47:38 by annihilator »
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
Re: rapid tyre wear
« Reply #4 on: 09 July 2018, 11:46:38 »
Yes, I agree; before my wishbones replacement - ATP kit, plus track rods and drop links - (thanks Serek) and proper all-wheel alignment on the Hunter machine at Tyre-Smart, Witham, I suffered similar tyre wear. After correction, as described, it drove as if on rails, even over the "tramlines" provided by heavy lorries on some local roads.  Get it done, your wallet will benefit!  :y :y :y
Ron.
  • Millennium Man
    • The missus mad
Re: rapid tyre wear
« Reply #5 on: 09 July 2018, 18:03:50 »
That wear is from the car's alignment being way out.
Whether this is caused by failed bushes or other component wear, or just badly set up, will need a pry bar and Mk1 eyeball to discover.
An MOT will tell you precisely sod all, so ignore that fact that it passed a few weeks ago.
I don't tolerate bickering, and I'm always grumpy.
And Lizzie Zoom says I'm a heartless bastid...and she's absolutely correct!
annihilator
  • Wirral
    • Elite,Tourer V6's
Re: rapid tyre wear
« Reply #6 on: 09 July 2018, 18:27:14 »
As I said, knew it was alignment just surprised it happened so quickly and will obviously get it sorted  :y
Page created in 0.17 seconds with 22 queries.
