Author Topic: Ncdr 1100  (Read 714 times)
annihilator
  • Wirral
    • Elite,Tourer V6's
Ncdr 1100
« on: 11 July 2018, 10:12:23 »
If I'm not bothered by lack of phone function can I fit one with a gid/cid, 4disc changer and relevant wiring mods to my '95 elite.
Cheers John.
Re: Ncdr 1100
« Reply #1 on: 11 July 2018, 10:15:50 »
No, you need to fit the display to match it due to the phone function :y
In the same way that a CCRT 2007/8 won't work with a normal display...
« Last Edit: 11 July 2018, 10:17:32 by Doctor Gollum »
annihilator
  • Wirral
    • Elite,Tourer V6's
Re: Ncdr 1100
« Reply #2 on: 11 July 2018, 11:27:16 »
I suggest you re-read the question and try again.  :D
Re: Ncdr 1100
« Reply #3 on: 11 July 2018, 12:33:55 »
Likewise my reply...
Alnico Blue
  • Costa del 'Saffend
    • 2001 2.6 CDX estate
Re: Ncdr 1100
« Reply #4 on: 11 July 2018, 12:46:08 »
Ease up you two  . . .   :(
John , I am not clear either on exactly what you mean here  . . .so can you post again .
I'm sure the good Doctor will advise once we are all clear on what you are trying/wanting to do  :-\
British made Celestion Alnico Blue = best sounding guitar speaker ever, sadly now made in China
Vega
  • The Netherlands
    • Omega Saloon 3.2
Re: Ncdr 1100
« Reply #5 on: 11 July 2018, 12:48:03 »
Yes
annihilator
  • Wirral
    • Elite,Tourer V6's
Re: Ncdr 1100
« Reply #6 on: 11 July 2018, 13:00:35 »
Firstly a '95 elite had an sc804 r/class with a multichanger in the boot, never had a phone option.
Secondly I've said in the post I'll need a matching gid/cid.
The point is that the ncdr1500 conversion is well documented and as I don't need the phone function can I use the ncdr 1100.Simples :y
Thanks Vega was pretty sure it could be done :)
Re: Ncdr 1100
« Reply #7 on: 11 July 2018, 13:06:10 »
If it can be done, then great, but you weren't clear re the display ;)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Ncdr 1100
« Reply #8 on: 11 July 2018, 13:29:38 »
Assuming you like a challenge, have a good understanding on the Parts Code Pairing together, handy with modifying or extending wiring looms etc, a Tech 2 would be handy if you wanted to get the Computer function to work correctly, Manual, Auto and other configs etc, Car / Audio Pass required, Steering Wheel Controls, RGB Cable etc etc.
Then youve got your existing Setup, Speakers, poss Amp, your Elites probably to old for Bose but does it have the Phillips Amp and Speaker option that were available of the CDX and Elites.
Has been done, some work involved, probably just easier to forget the whole idea and send me the 1100 and Screen.  ;D ;)
  • Solihull
    • 3x 3.2 V6 Elite Saloons
Re: Ncdr 1100
« Reply #9 on: 11 July 2018, 14:08:20 »
Has NCDR and GID /CID screen as I read it.
So if your good with modifying and building extra looms (best done on a traffic master loom) and know someone with a Tech II who can tweak the car options on the screen unit (eg. HID's)?
  • Millennium Man
    • The missus mad
Re: Ncdr 1100
« Reply #10 on: 11 July 2018, 18:11:16 »
Perfectly possible...
https://www.omegaowners.com/forum/index.php?topic=87632.0
That was my MFL MV6
You'd have a bit more to do on a pre MFL due to MID wiring.
I did same mod to my MFL TD Elite, and to my current Zafira-A
I don't tolerate bickering, and I'm always grumpy.
And Lizzie Zoom says I'm a heartless bastid...and she's absolutely correct!
Vega
  • The Netherlands
    • Omega Saloon 3.2
Re: Ncdr 1100
« Reply #11 on: 11 July 2018, 19:30:47 »
I copied this from my thread at the OpelOmegaPortal.nl
NCDR 1100
CID
CDC3
Telematica unit
Adapter cable
annihilator
  • Wirral
    • Elite,Tourer V6's
Re: Ncdr 1100
« Reply #12 on: 11 July 2018, 20:11:16 »
Cheers, looks impressive  :y
  • Millennium Man
    • The missus mad
Re: Ncdr 1100
« Reply #13 on: 11 July 2018, 20:13:04 »
CID is more impressive than GID, although less reliable.
  • Solihull
Re: Ncdr 1100
« Reply #14 on: 11 July 2018, 20:14:01 »
What's that packet marked 'blue' in the glovebox?  :o ::) :D
Page created in 0.126 seconds with 23 queries.
