Author Topic: Some parts I have for sale  (Read 2308 times)
Ironingboard
  • Edinburgh
« on: 22 July 2018, 22:52:42 »
It’s been a long time since I was on here and since then I sold my Omega for a lot less money than I thought, anyway I have collected a number of bits and pieces over my ownership time and never got around to fitting them so I’m trying to recoup some of my money. The parts were for a W Reg 3.0 Elite, but please check the part numbers to make sure the parts are correct. Anyway here is a list of the bits I have to sell, send me a PM if interested.
New Genuine Vauxhall Parts
1x Lower Rear Rubber Spring seat    Part No. 90250800      £8
1x Upper Rear Rubber Spring seat   Part No. 90447199      £4
1x Rear suspension arm, front top rubber damper (goes above the large donut bush on the rear suspension arm)   Part No. 90447991         £3
4x Front Shock absorber Nuts and Bolts   (For a 2.0 Litre I think M12x1.5x55)   Part No. 11096171   £4
Front Engine Bay Fuel Pipes retaining clip   (fuel pipe to heater hose)   Part No. 90467190      £2
2x Front Anti-roll bar bushes      Part No. 90445625      £8
Front air Throttle seal       Part No. 90512145      £2
Rear Passenger Ashtray      Part No. 90363769      £5
2x Coolant Transfer pipe seals (pipe the connects to thermostat)   Part No. 9129999   £4
6x Rear backing plate bolts   Part No. 11092671      £6
1x Rear flange securing nut   Part No. 90075162         £1
1x exhaust manifold to block gasket multilayer type   Part No. 24416110   £10
3x door card folding storage rubber dampers   Part No. 9196804   £1
6x stud and 7x nuts for securing exhaust manifold to bloc    Part No. (Studs) 90106924 (nuts) 90502418      £10
2x nuts used to secure rear control arm    Part No. 90538058   £2
2x nuts used to secure exhaust manifold to catalytic converter drop down pipe   £4 Part No. 90570845
2x exhaust manifold to cat gas seals    Part No. 90499289   £6
1xseal ring throttle valve body to induction manifold   Part No. 90412566   £1
2x rear shock absorber bumper stops Part No. 90468006
Rear Shoe Pins       24420393
Rear Show Pin Washers      6663706
New OEM Parts
1xlemforder/boge rear suspension arm donut bush      £20
1x rear wheel bearing                   £20
Ironingboard
  • Edinburgh
Re: Some parts I have for sale
« Reply #1 on: 22 July 2018, 22:54:34 »
For some of the parts that don't have prices, make me an offer.
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #2 on: 22 July 2018, 23:08:26 »
PM sent  :y
Ironingboard
  • Edinburgh
« Reply #3 on: 23 July 2018, 15:18:53 »
For some reason I cannot edit my original parts list. Anyway I've done a better inventory and found some other bits that people might be looking for.
4x Front Shock absorber Nuts and Bolts   (For a 2.0 Litre I thinkM12x1.5x55)   Part No. 11096171   £4
1x Front air Throttle seal          Part No. 90512145      £2
3x nuts used to secure rear control arm    Part No. 90538058(old part no.)/13136972   £3
1x Transmission/Oil seal      Part No. 8644709      £1
1x Copper sump washer      Part No. 11023582      £1
4x O-ring seals    Part No. 90467275                  £2
2x nuts used to secure exhaust manifold to catalytic converter drop down pipe   Part No. 90570845     £4
3x rear brake return spring       Part No. 90079237            £6
3x plastic engine breather retaining bolt to induction   Part No. 11096061   £2
1x throttle breather retaining bolt, plastic cover      Part No. 90467617   £1
1x seal ring throttle valve body to induction manifold   Part No. 90412566      £1
2x rear shock absorber bumper stops (2-piece assembly)   Part No. 90468006   £10
4x Rear Shoe Pins       Part no. 24420393   £4
4x Rear Shoe Pin Washers   Part No. 6663706      £4
New OEM Parts
1x lemforder/boge rear suspension arm donut bush      £20
1x rear wheel bearing    Part No. 90510542         £20
Used OE and genuine Parts – all working
2x front drop links   (Removed to spray paint the metal but never refitted, almost new)      £20
1x Set of 3.0 or 2.5 BERU Spark Plugs Leads         £20
1x aux water pump    Part No. 90448286         £20
« Reply #4 on: 23 July 2018, 15:22:14 »
Any idea what mileage the used bits have done? Ta  8)
Ironingboard
  • Edinburgh
« Reply #5 on: 23 July 2018, 15:29:11 »
The Aux Coolant pump was about 50k. The leads were about 25k and the drop links were 0 as I fitted them, thought about the exposed metal rusting and took them off to paint them, put the old ones back on but never had the time to refit the painted ones  :-\
biggriffin
  • huntingdon, Hoof'land
    • Vectra in a posh frock.
« Reply #6 on: 23 July 2018, 19:28:47 »
Pm sent. :y
Hoof'land storeman.
Ironingboard
  • Edinburgh
« Reply #7 on: 27 July 2018, 22:26:15 »
Updated list
£4
2x Rear suspension damper block to crossmember bolts      Part No. 11094161   £2
2x Trim clips Part No. 2208843      £1
New OEM Parts
1x Lemforder/Boge rear donut bush   Lemforder 1606301 (vx Part No. 90447156)   £20
2x front drop links   (Removed to spray paint metal but never refitted, almost new)      £15
2x Trim retaining clip for boot trim opening     Part No. 90457577      £4
Ironingboard
  • Edinburgh
« Reply #8 on: 29 July 2018, 21:22:06 »
Update parts list of whats still available.
New OEM Parts
1x lemforder/boge rear donut bush   lemforder 1606301 (vx Part No. 90447156)   £20
Page created in 0.038 seconds with 21 queries.
