Author Topic: Sony experia loudspeaker mutes volume in calls  (Read 451 times)
grifter
  • Paisley, Scotland
  • Omega 2.6 owner
    • Omega 2.6
« on: 07 August 2018, 22:15:08 »
Hi
Wondering if anyone knows how I can fix this. I have Sony Experia mobile and in a call if I turn on the loudspeaker the sound just mutes when I do that. Pretty annoying having to plaster the phone to my head and if there is any background noise I can't hear what is being said.
Cheers for any tips. I've tried all the usual stuff in call settings, and phone is up to date software etc.
Re: Sony experia loudspeaker mutes volume in calls
« Reply #1 on: 08 August 2018, 00:32:09 »
Turn the volume up on the side  ::)
grifter
  • Paisley, Scotland
  • Omega 2.6 owner
    • Omega 2.6
« Reply #2 on: 08 August 2018, 06:35:50 »
Volume is at max on the side when on normal speaker but it goes dead as soon as the loudspeaker is put on; will try that of course.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #3 on: 08 August 2018, 15:36:03 »
The Hands Free Speaker is probably at the back of the phone, so external Cover?, something blocking it, got wet and the speaker is duff or or got sticky wet and has dried up of the speaker is fukced.
Or, in settings (somewhere) phone thinks its using Bluetooth or Headphones when you speak the speaker on.
jimmy944
  • Kidderminster
    • Swedish soot chucker
« Reply #4 on: 08 August 2018, 15:53:18 »
Every phone I've had in the last few years "remembers" volume settings for each output method. So you will probably have to switch to a loudspeaker, then up the volume. Which is what I thing DG was getting at.
  • Up North
    • Astra 2.0 diesel
« Reply #5 on: 08 August 2018, 16:12:38 »
No he wasn't. He was being a sarky bastid.  ;D
If you are offended by anything I post, sorry. Just thought I'd get that in now.
jimmy944
  • Kidderminster
« Reply #6 on: 08 August 2018, 16:17:00 »
I was trying to give the benefit of the doubt. Then again, what doubt  ::)  ;D
« Reply #7 on: 08 August 2018, 16:23:22 »
Oi >:( I am still in the room...  :P
Currently on my fourth Xperia... Present one, XZ Premium, has three volumes, all controlled by the side buttons.
If the speaker works for media playback, then it's a settings problem... If it doesn't, then you didn't buy the waterproof one that you thought you had ;)
grifter
  • Paisley, Scotland
  • Omega 2.6 owner
    • Omega 2.6
« Reply #8 on: 09 August 2018, 21:33:30 »
All volumes work, except the speaker, and I don't see any settings for it, just ringing volume, media volume and alarm volume. Turned off all the other sound fancy settings like clear audio and normaliser just to see if that made any difference.
« Reply #9 on: 09 August 2018, 22:10:54 »
Do you use it with headphones or Bluetooth for hands-free?
grifter
  • Paisley, Scotland
  • Omega 2.6 owner
    • Omega 2.6
« Reply #10 on: 10 August 2018, 07:51:28 »
Nah, just as is, no headphones or use Bluetooth. Funnily enough I took rubber cover off last night and back plate is all cracked. Don't remember that being broke.
« Reply #11 on: 10 August 2018, 08:54:01 »
Well, at least you know what's wrong with it :y
Mister Rog
  • Wales
    • Volvo XC70
« Reply #12 on: 11 August 2018, 12:53:14 »
I once had a similar problem with a phone. It had a model specific cover, however it partially blocked mic/speakers. Fixed with a very small and sharp blade.
“The desire to be a politician should bar you for life from ever becoming one.” Billy Connolly
grifter
  • Paisley, Scotland
  • Omega 2.6 owner
    • Omega 2.6
« Reply #13 on: 12 August 2018, 17:40:01 »
I checked with cover off and it isn't that either. You can hear it distinctly mute as soon as you press loudspeaker.
Page created in 0.164 seconds with 21 queries.
