Pages: 1 2 3 4 5 6 7 [8] 9   Go Down
Author Topic: Zafira Tourer - Service ESP  (Read 3050 times)
    • 3.2 Elite & Zafira Tourer
Re: Zafira Tourer - Service ESP
« Reply #105 on: 23 September 2018, 13:50:54 »
Also fact live data still says 0v to the motor pump as well.  :-\
What does it say on a working one?  Is that the return pump? If so, that would only be activated under antilock conditions.
Oh.
I can't test a working one, unless you mean try the Omega?
Got a VW, Audi, Skoda or Seat? I have full Diagnostic software VCDS to read and program your car. Need something enabling? Perhaps full diagnostic? Drop me a PM. Can diagnose in Camberley or Osterley Area.
« Reply #106 on: 23 September 2018, 13:51:57 »
Your reader might not do all ECUs.  So get a set of schematics from somewhere, and pour over them.  Pretty certain you can get a day subscription to GM's EU TIS, because we can't recommend dodgy copies of the software here, can we.
That said, does sound likely its the ABS causing a problem.  But if the ABS/ESP is working, I would defo be checking the connectors etc before condemming anything.
It's not, another weekend test was taking it on the by-pass.
I stamped on the brakes at 70mph, easily locked up the fronts, with no pedal feedback.
so 0 volts ,abs pump not working
did you find the abs relay , mentioned many posts ago
Yes, the large 60amp one in the engine bay, there was another fuse as well 25amp Micro2 fuse in the engine bay too.
The larger one had a cover to remove on top, so you could visually inspect as well.
Both tested with a multi-meter, both had number "close to one" as per research suggested it should.
Also to add, it's a new multimeter, not old POS one I had before.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #107 on: 23 September 2018, 13:53:35 »
relay , not fuse  ;)
  • Millennium Man
    • The missus mad
« Reply #108 on: 23 September 2018, 13:55:14 »
Oh.
I don't know what live data your reader provides, hence I was asking/suggesting if its the return pump, I suspect it would read 0 under normal conditions.
It is a different unit to the Omega ones, so the comparison is meaningless.
I don't tolerate bickering, and I'm always grumpy.
And Lizzie Zoom says I'm a heartless bastid...and she's absolutely correct!
« Reply #109 on: 23 September 2018, 14:04:43 »
It allows me to pick a bunch of data, as seen in photos. So reasonable enough, speed sensor etc, must be about 25 values of live data ABS system.
Hummmm relay, book tells me about fuses, but not relays. As always with this car, technical data is low online.  :(
Presume it would be a relay in the engine bay fuse box?
« Reply #110 on: 23 September 2018, 14:07:26 »
Forums are full of ZafB owners with same lights on and me and it's all down to ABS control module, sod all on ZafC but perhaps they are only just starting to age now.
« Reply #111 on: 23 September 2018, 14:27:05 »
So I can't find overview on ZafC, but found one for ZafB
https://fusesdiagram.com/opel-vauxhall/fuses-and-relay-opel-vauxhall-zafira-b.html
There are no ABS relays, only fuses.
« Reply #112 on: 24 September 2018, 20:39:13 »
So, it’s all fixed. Turns out it was a washer inside the wheel hub, which had failed. I had seen it as a possible cause, but I could not get any codes to suggest this.
I’m £150 lighter as a result, but happy it’s all resolved.
Sir Tigger QC
    • BMW 530d & 2 Fords
« Reply #113 on: 24 September 2018, 21:32:29 »
Good news and better than a failed ABS module!  :y
JC is not The Messiah, he's a very naughty boy!!
  • Up North
    • Astra 2.0 diesel
« Reply #114 on: 24 September 2018, 22:15:53 »
People are very quick to condemn the dealers. Diagnosed and fixed in a day, at a reasonable price.
If you are offended by anything I post, sorry. Just thought I'd get that in now.
« Reply #115 on: 24 September 2018, 22:18:08 »
Yeah. for a main dealer it’s quite reasonable
jimmy944
  • Online Online
  • Kidderminster
    • Swedish soot chucker
« Reply #116 on: 24 September 2018, 22:35:53 »
Glad it was a cheap fix (although many on here would malign £150).   :y
pscocoa
  • Sandhurst Berkshire
  • Try VW Phaeton as replacement for Omega
    • Phaeton V6, VX Astra SE
« Reply #117 on: 25 September 2018, 16:40:55 »
Was that Eden Camberley??
  • Millennium Man
    • The missus mad
« Reply #118 on: 25 September 2018, 18:05:34 »
Goes to show how good that shitty diags kit is ;)
« Reply #119 on: 25 September 2018, 20:07:23 »
£150 kit stuff  :(
Pages: 1 2 3 4 5 6 7 [8] 9   Go Up
Page created in 0.121 seconds with 22 queries.
