Pages: 1 2 [3] 4 5 6 7 8 9   Go Down
Author Topic: Zafira Tourer - Service ESP  (Read 3976 times)
Re: Zafira Tourer - Service ESP
« Reply #30 on: 15 September 2018, 00:13:30 »
Grrr. So the software that cannot be named canít read ABS module either.  >:(
Guess I need to splash some cash and get serious code reader like this:
http://www.diagnostic-world.com/pages/iCarsoft_OP_II_Vauxhall_Opel_Oil_Service_Reset_Multi_System_Diagnostic_Tool__212698-z=656151&p=111378.cfm
Be a lesson there somewhere ::)
But, yes, you should buy that ;)
Sir Tigger QC
    • 2 Fords
« Reply #31 on: 15 September 2018, 09:19:05 »
Or buy a code reader that can read all codes on all cars.  :y
I have one of these bought secondhand on ebay for £60 and it clearly was hardly used.  :y
JC is not The Messiah, he's a very naughty boy!!
  • Millennium Man
    • The missus mad
« Reply #32 on: 15 September 2018, 10:20:37 »
Trouble with generics that claim "can do xyz" is that they can usually only do it on a subset of vehicles they list once you get beyond drivetrain.  Some are better than others.  I suspect tunnie needs a recommendation for something that has been tested against a Zaf-C ABS unit....
...or bung a local garage a £20 note, no receipt, for a read.
I don't tolerate bickering, and I'm always grumpy.
And Lizzie Zoom says I'm a heartless bastid...and she's absolutely correct!
    • 3.2 Elite & Zafira Tourer
« Reply #33 on: 15 September 2018, 10:38:34 »
Today Iíll order one I linked to, garages around here want £70 just for a diag. So money well spent, plus Insignia is strong contender for 3.2 replacement.
As even if I get a diag done here, would need another one to clear coders after Iíve changed the sensor.
Got a VW, Audi, Skoda or Seat? I have full Diagnostic software VCDS to read and program your car. Need something enabling? Perhaps full diagnostic? Drop me a PM. Can diagnose in Camberley or Osterley Area.
  • Millennium Man
    • The missus mad
« Reply #34 on: 15 September 2018, 11:00:28 »
You need to learn how to drop a bung.  Can't do that surfing the net ;)
« Reply #35 on: 15 September 2018, 12:11:34 »
I called. Local indies, multiple ones. Cheapest £69.
« Reply #36 on: 15 September 2018, 12:17:49 »
Ordered. Should pay for itself quickly I think.
« Reply #37 on: 20 September 2018, 20:50:46 »
So, the saga continues.  :(
Code reader received and updated, once i tracked down a windows laptop capable. I can read all modules correctly and see live data. This is the issue:
ESP on the dash, car runs and drives fine, not in limp mode all instruments working.
Looking in ECBM which I understand is where ABS module is....
There are no codes.  :(  :-\
But if I clear the ECBM
The ABS/Traction lights go out and all is well, until you drive for 15 seconds and its back on.  >:(
In Live data, I can see kph of sensors if I roll forwards back, both sides, so the sensors appear fine. I did see this about ABS Pump motor at 0v, so I checked fuse in engine bay, all good.  :-\
So I'm at a bit of a loss to the cause, and may have to go to the dealer.  :(  :-\
Sir Tigger QC
    • 2 Fords
« Reply #38 on: 20 September 2018, 21:10:31 »
ABS ECU.  Do you get any 'feedback' through the brake pedal when the light comes back on?
« Reply #39 on: 20 September 2018, 21:21:42 »
Try chassis control module ::)
« Reply #40 on: 20 September 2018, 21:43:51 »
No feedback through pedal when light comes on, braking behaves normally.
Nothing brake related in there, no codes, no live data relating to braking.
All ABS sensor info is in Electronic Brake Control module, along with ABS pump voltage.
« Reply #41 on: 20 September 2018, 22:01:27 »
The issue isn't necessarily in that module.
Did you reset all the service memories when you changed the oil?
« Reply #42 on: 20 September 2018, 22:02:20 »
Just the oil life, via the dash controls.
  • Up North
    • Astra 2.0 diesel
« Reply #43 on: 20 September 2018, 22:20:11 »
The garage didn't reset mine after the oil change, so I did it via the menu on the dash. No problems so I can't see you've done anything that would bring a code up.
If you are offended by anything I post, sorry. Just thought I'd get that in now.
« Reply #44 on: 20 September 2018, 22:25:15 »
Same. Just standard oil reset.
Fact I reset codes for brake module turns light off, suggests fault here.
Also came on couple weeks and few hundred miles after Service.
Shall be admitting defeat and booking it into dealer tomorrow.  :(
Pages: 1 2 [3] 4 5 6 7 8 9   Go Up
Page created in 0.123 seconds with 21 queries.
