Pages: 1 2 3 4 5 6 [7] 8 9   Go Down
Author Topic: Zafira Tourer - Service ESP  (Read 3048 times)
    • 3.2 Elite & Zafira Tourer
Re: Zafira Tourer - Service ESP
« Reply #90 on: 22 September 2018, 09:51:21 »
Breakthrough
Found inside the "Power Steering Control Module" a bunch of codes, thanks to TB for suggesting all modules, I cleared them and ABS EBCM error to clear dash error. Went for a drive, ESP came back on and went back to power steering module, had this code:
U0415: Invalid Data Received from Electronic Brake Control Module.
Off to Google....
EBCM itself had no codes...
2 mins Google and I think it still suggests ABS pump  :(
Good in a way I guess.
https://www.troublecodes.net/ucodes/u0415/
Probable Cause: Wiring, Wheel speed sensors, Defective ABS control module, Defective ABS pump, PCM.
Got a VW, Audi, Skoda or Seat? I have full Diagnostic software VCDS to read and program your car. Need something enabling? Perhaps full diagnostic? Drop me a PM. Can diagnose in Camberley or Osterley Area.
« Reply #91 on: 22 September 2018, 09:59:30 »
other codes, before I cleared them:
U0140 - Lost communication with Body Control Module.
U0121 - Lost communication with Electronic Brake Control Module
U0100 - Lost communication with Engine Control Module
U0415 - Invalid data received from Electronic Brake Control Module
  • Online Online
  • Up North
    • Astra 2.0 diesel
« Reply #92 on: 22 September 2018, 11:27:30 »
I read something about this yesterday and I'm buggered if I can find it again. Turned out to be chafed wiring under the battery tray.
If you are offended by anything I post, sorry. Just thought I'd get that in now.
« Reply #93 on: 22 September 2018, 12:40:42 »
Searching myself for this, can't find anything.
  • Millennium Man
    • The missus mad
« Reply #94 on: 22 September 2018, 19:05:52 »
In steering ECU?
Looks like a CAN issue, and be checking the wiring between all these ECUs.
I don't tolerate bickering, and I'm always grumpy.
And Lizzie Zoom says I'm a heartless bastid...and she's absolutely correct!
« Reply #95 on: 22 September 2018, 20:50:12 »
In steering ECU?
In power steering, yes. But after clearing and then driving only 415 returned.
  • Millennium Man
    • The missus mad
« Reply #96 on: 23 September 2018, 10:20:56 »
Before condemming any component, just check wiring integrity between them.  Also, be aware, with CANBUS, there may not be a direct cable between those, and it might pass through other ECUs on the way, any of which could potentially upset the signal (though unlikely, unless they are in some poorly tested error routine themselves).
Of all the many advantages of CAN, this is the biggest downside.
Hence, the suggestion to go through everything on the same CANBUS (no idea how many the Astra-J/Zaf-C have, previous models had 3 - high speed, medium speed and slow speed).  I would imagine ABS would be on high or med speed, but you need to check.
« Reply #97 on: 23 September 2018, 13:25:50 »
So technical knowledge on the Zaf-C is thin on the ground, this thread is better than Zaf forums. So no idea which CANBUS would be which in terms of speed, but....
Yesterday I went through every single module I could under "Zafira-C" - From the park distance module, to radio, transmission, everything. Only area which had codes were power steering module, listed the above.
  • Millennium Man
    • The missus mad
« Reply #98 on: 23 September 2018, 13:41:21 »
Your reader might not do all ECUs.  So get a set of schematics from somewhere, and pour over them.  Pretty certain you can get a day subscription to GM's EU TIS, because we can't recommend dodgy copies of the software here, can we.
That said, does sound likely its the ABS causing a problem.  But if the ABS/ESP is working, I would defo be checking the connectors etc before condemming anything.
« Reply #99 on: 23 September 2018, 13:43:14 »
It's not, another weekend test was taking it on the by-pass.
I stamped on the brakes at 70mph, easily locked up the fronts, with no pedal feedback.
« Reply #100 on: 23 September 2018, 13:45:53 »
Also fact live data still says 0v to the motor pump as well.  :-\
  • Millennium Man
    • The missus mad
« Reply #101 on: 23 September 2018, 13:47:40 »
OK, still check the connectors though.  It probably wont take long, and if its a free fix, you'll be pleased.  But sounds like you'll be swapping the part out.
Check if part replacement needs programming in, or if its simply plug and pray.  If it does need programming in, those repair services look a lot more appealing ;)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #102 on: 23 September 2018, 13:48:17 »
so 0 volts ,abs pump not working
did you find the abs relay , mentioned many posts ago
  • Millennium Man
    • The missus mad
« Reply #103 on: 23 September 2018, 13:48:35 »
What does it say on a working one?  Is that the return pump? If so, that would only be activated under antilock conditions.
« Reply #104 on: 23 September 2018, 13:50:16 »
Yes, the large 60amp one in the engine bay, there was another fuse as well 25amp Micro2 fuse in the engine bay too.
The larger one had a cover to remove on top, so you could visually inspect as well.
Both tested with a multi-meter, both had number "close to one" as per research suggested it should.
Pages: 1 2 3 4 5 6 [7] 8 9   Go Up
Page created in 0.17 seconds with 22 queries.
