Author Topic: main cooling radiator  (Read 1380 times)
flyer 0712
« on: 19 September 2018, 17:18:47 »
I have a main cooling radiator for a facelift omega 2.2 automatic was fitted to my  2002 model for just one year so is in great nick however there is a slight snag,,,, the automatic has a separate oil cooler that is bolted to the front of the radiator but who ever fitted this rad just cable tied the oil cooler to the front of it and it worked as it should with no probs as regard the size of the rad it is correct and the  hose connections and switch connections are the same as the omega but this rad has the oil cooler inside the rad on the left hand side as viewed from the front I believe it fits other omegas maybe a bit earlier years as I say only a year old and was removed on several occasions because of overheating so some marks on it  and it turned out it was the head gasket so scrapped the car.  collection only from LU5 area Houghton Regis Dunstable border,, rad fan air con fan and oil cooler rad as well for 2.2 f/lift available all free to collector rather than dump the lot  so any more info required please  just ask...thanks..
flyer 0712
Re: main cooling radiator
« Reply #1 on: 25 September 2018, 08:41:27 »
radiator and all parts collected and fitted to a very grateful omega owner and his car works a treat admin please now lock  thanks. :y
