Pages: 1 2 [3]  All   Go Down
Author Topic: front lower wishbones  (Read 1124 times)
  • Millennium Man
    • The missus mad
Re: front lower wishbones
« Reply #30 on: 23 September 2018, 16:26:03 »
Not used Mister Auto, but have seen ATP wishbones (poor) and tried to use ATP (never posted the boot struts).
If your current wishbones are GM and have good balljoints, stop dicking around, poly the fronts (£50) and press new GM bushes (about £20 each) in the rear, then take if for a full geometry check (not 4 wheel alignment or "laser alignment" of any other substandard tosh) to WIM settings, then worry about the rearward bushes again in 3 to 4yrs (probably much longer, as you clearly don't use the cars capabilities).
If you *MUST* have shiny wishbones, GM are too expensive (and you should be able to negotiate significantly better than 10%), so your choice probably becomes Lemforder from a reputable supplier (too many fakes about).
I don't tolerate bickering, and I'm always grumpy.
And Lizzie Zoom says I'm a heartless bastid...and she's absolutely correct!
Lizzie Zoom
  • Ashford, Kent
    • Omega 3.2 V6 ELITE 2003
« Reply #31 on: 23 September 2018, 16:36:29 »
Thanks TB, very helpful :-* :-* :y
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
« Reply #32 on: 23 September 2018, 16:37:03 »
Who are Lemforder and why are they so superior, TB?
Ron.
Lizzie Zoom
  • Ashford, Kent
« Reply #33 on: 23 September 2018, 17:17:48 »
Apart from the main WIM, just over 2 hours from me, is there any closer to me in Malta Kent?  ??? :D ;)
amba
  • Medway towns
    • 2003.BLACK 3.2 ELITE
« Reply #34 on: 23 September 2018, 17:25:46 »
Tyre Pro in Strood/Rochester Bridge have the correct equipment and setup and have also got WIM,s setting as ..NickW.Weds and myself have all used them with good results.
The guys there also know how to use the machine properly and as they have dealt with several fussy Omega Owners over the years don't try fobbing you off with..." its in the Green so that's ok Guv". :)
Bigron
  • Witham, Essex
« Reply #35 on: 23 September 2018, 17:27:29 »
How near to Witham (Essex) are you, Kate? Albs and I have had excellent service from Tyre-Smart with their Hunter full geometric alignment machine, using the WIM settings that I gave them, similar to what amba just said. :y
Ron.
Lizzie Zoom
  • Ashford, Kent
« Reply #36 on: 23 September 2018, 17:29:58 »
Thanks amba :y
Is that the "Protyre" chain, which I actually have 3 branches of here in Ashford? ;)
amba
  • Medway towns
« Reply #37 on: 23 September 2018, 17:39:23 »
That's correct Lizzie although quality of operatives and knowledge of how to use it differ hugely from 1 branch to another.
I have used the place on the Orbital Park near you by MacDogbits and found them pretty shoddy tbh. :(
Their policy was Green was good enough and when I asked them to set it at specific settings guy said he could due to wear in bushes and old joints...that was total b***lxs as all parts had just been replaced.They may of changed now though as that was 6/7 years ago now and you seem a forcefull lady so imagine they will do as you tell them to  ;D
Lizzie Zoom
  • Ashford, Kent
« Reply #38 on: 23 September 2018, 17:42:30 »
That is great amba. Many thanks! :-* :-* :y
A plan is now coming together.  I'm going to Vx tommorrow and forcing my hand on the parts. We will see if they budge, but they know I am a very good long term customer :D ;)
Strood is no distance at all for me.
« Last Edit: 23 September 2018, 17:44:38 by Lizzie Zoom »
  • Chatham, Kent
  • Rover Metro 1.8VVC
    • 3.0l Elite estate
« Reply #39 on: 23 September 2018, 18:07:05 »
They're not afraid of making the adjustments either; the last time I had my car done,he just got on with freeing off and adjusting the rear adjusters after we both decided that the front cambers were slightly off WIM's recommended setting but as they'd been like that for 4 years we weren't going to disturb them.
amba
  • Medway towns
« Reply #40 on: 23 September 2018, 18:15:06 »
45 minutes drive to Strood for you Lizzie and they even offer free coffee.
Shops within walking distance so a woman’s heaven  :D
Lizzie Zoom
  • Ashford, Kent
« Reply #41 on: 23 September 2018, 18:41:23 »
Yep, all good! 8) ;D :y
Lizzie Zoom
  • Ashford, Kent
« Reply #42 on: 23 September 2018, 18:42:27 »
Good info. Thanks Nick 8)  :-* :y
  • Millennium Man
    • The missus mad
« Reply #43 on: 23 September 2018, 19:08:06 »
Ron.
Lemforder are now part of the ZF group, based in Germany.  They manufacture quality parts for both aftermarket and OE.  Sadly, because of their name and reputation, there are a lot of fakes around.
Pages: 1 2 [3]  All   Go Up
Page created in 0.13 seconds with 21 queries.
