Author Topic: 3.2 issue.  (Read 6098 times)
3.2 issue.
« on: 29 September 2018, 11:48:51 »
The car: 3.2 manual estate. Been parked up for 3 years. Fresh fuel added then driven 77 miles. Was fine initially, albeit with lifter noise, but by end of journey car cutting out and missing, eventually stalling. Won't rev past 4k.
Codes 0340 and 0300.
Car has since been sat a week.
Coil packs off and plugs out. 135 pack as new, plugs fouled and stink of fuel. 246 pack shot and plugs fouled no smell of fuel.
Plugs cleaned and refitted along with v good 246 replacement pack. Known good cam sensor also fitted.
Can of lifter treatment added.
Car then started and allowed to idle. Still very tappety but improving slightly as it warmed up. All the lifter noise is from the rearmost two tappets on 5 (1 exhaust and 1 inlet) I suspect that with a couple of oil changes and some more treatment these will eventually settle down.
As the car warmed up it started to mis. Revs applied and whilst it revs OK, still no more than 4k. Lift off and it splutters. Unplugging MAF made no difference. Repeat and it stalls. Codes 0340 and 0300.
135 flooding. Pull fuse 18 and it starts fine but idles rough when warm. Start WOT and again starts fine and revs as soon as running.
Current thinking is that the crank sensor is starting to breakdown causing an intermittent failure which shuts the engine down mid flow.  :-\
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
Re: 3.2 issue.
« Reply #1 on: 29 September 2018, 12:12:26 »
Is this your old TVP car Al?
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: 3.2 issue.
« Reply #2 on: 29 September 2018, 12:17:25 »
bore wash  :-\
try a little oil in the bores ,may help those sticking  zorst valve too
the top end / cams would be dry after being laid up so long
had it been a 4 pot ,i'd whip the cam cover off and examine the cam ,valves etc
not so easy on a 6 banger  :(
« Last Edit: 29 September 2018, 12:28:26 by dave the builder »
0795omega
Re: 3.2 issue.
« Reply #3 on: 29 September 2018, 12:37:30 »
good luck with that!! sounds like engines toast!!
Re: 3.2 issue.
« Reply #4 on: 29 September 2018, 13:22:47 »
The car was given a once over before initial starting and I don't believe that if it was mechanically knackered that it would have lasted 7 miles, let alone 70+.
It will clearly need some tlc, and is due a belt on time... Has done about 9k in the last six years.
Plug wells are clean and dry, so didn't particularly want to disturb the covers just yet.
Re: 3.2 issue.
« Reply #5 on: 29 September 2018, 16:10:44 »
P0340 is cam sensor, so start there.
Re: 3.2 issue.
« Reply #6 on: 29 September 2018, 16:53:02 »
Done with no improvement. Although known good second hand.
Incidentally this car has previously had a cam sensor changed... One of only two 3.2s I have encountered with a 0340 code.
« Last Edit: 29 September 2018, 16:56:06 by Doctor Gollum »
  • Auckland
    • Mazda MPV
Re: 3.2 issue.
« Reply #7 on: 29 September 2018, 17:02:08 »
Wiring fault?
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: 3.2 issue.
« Reply #8 on: 29 September 2018, 17:25:41 »
where does the engine ECU live on these ?
somewhere that gets wet via rust holes or scuttle flood  :-\
  • Auckland
    • Mazda MPV
Re: 3.2 issue.
« Reply #9 on: 29 September 2018, 17:31:20 »
In the triangular fuse box next to the battery.
The wiring to the cam sensor hops across to the front of the engine - IIRC it is one of the cables that has to be evicted from the cable tray across the front of the cam-belt cover each time the cam-belt is changed :-\
Re: 3.2 issue.
« Reply #10 on: 29 September 2018, 17:37:08 »
What are the fuel trims doing? Thinking it may be fine when running open loop but dying when closed loop due to a poor lambda sensor on one bank?
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: 3.2 issue.
« Reply #11 on: 29 September 2018, 17:52:06 »
Thanks  :y
so, easy (ish) to meter out the cam sensor to ECU loom plus check the ECU plugs for crud
Good point  :) live data is great at finding electrical gremlins
and a stethoscope is good to pinpoint mechanical
not unheard of for a cam to snap on some vauxhall engines or valves stick and bend(4 pot)
probably unheard of on a v6 though  :-\
i'm new to these v6 lumps  :-[
Re: 3.2 issue.
« Reply #12 on: 29 September 2018, 18:15:04 »
Not so, pops out of the end of the 246 cable tray and lives on the front inlet side of 2 above the thermostat pipe.
Wiring fault?
Possibly, but no evidence of rodent intervention.
Re: 3.2 issue.
« Reply #13 on: 29 September 2018, 18:30:53 »
It did, very briefly throw up a code for B1S1. But couldn't get it running long enough to repeat.
Code reader is a generic one, so some of the following is a little confusing.
Below is the detail from screen shots of all six pages of live data engine at temp and idle...
Fuel System 1    OL Fault
Calculated Load     5.1%
Engine Coolant Temp   80°
STFT1   0.0%
STFT3   - 40.6%
LTFT1   0.0%
LTFT3   -39.8
STFT2   0.0%
STFT4   -39.1%
LTFT2    0.0%
LTFT4   - 38.3%
RPM    600/rpm
Vehicle Speed   0 mph
Ignition Advance   0.0
Intake Air Temperature   27°C
Airflow   6.50g/s
Throttle   3.5%
O2V B1S1   0.085V
STFT B1S1   0.0%
O2V B1S2   0.485V
STFT B1S2   99.2%
O2V B2S1   0.045V
STFT B2S1   0.0%
O2V B2S2   0.62V
STFT B2S2   99.2%
ajsphead
  • North Somerset
    • Omega 2.2 DTi estate
Re: 3.2 issue.
« Reply #14 on: 29 September 2018, 20:05:53 »
Do I understand that it's fine when cold, just misses and overfuels when hot?
If so then problem could be breakdown within coil packs leading to inadequate spark or
faulty lambdas, probably post cat or
faulty coolant temp sensor reading low, making ECU enrich mixture (unlikely in this case) or
breakdown within spark plugs causing weak spark or
injectors sticking open causing the duration to be artificially long or
the usual crank sensor or
any attendent wiring or
something really silly like birds nest in the airbox.
It needs someone who can read the V6 dataset to comment on the airflow and lambda readings.
I'd give it a full thorough service including some internal cleaning potions that actually work then if not cured you could test each suspect component at a time till you find the duff one, or do it on a probablility and likelihood basis.
Page created in 0.035 seconds with 21 queries.
