Author Topic: No heating/ tepid  (Read 1061 times)
noknowledgemike
  • hertfordshire
    • omega 2.6 estate
No heating/ tepid
« on: 07 October 2018, 12:04:30 »
Hi
I have searched through the topics and have found lots of help, but I need a bit more if possible.
I have very tepid heating. I have changed the HBV. I have flushed out the heater matrix. Both pipes running into the matrix are now hot but no heat.
I ask, the 2 pipes that run into the heater matrix, can you tell me their routing, where they go to?
The 3 pipes that go into the HBV, where do they go to?
Is it likely the heater matrix is defective? is this the last place to check or change.
I ask pipework routing just in case I put them on the wrong connectors.
The 2 pipes that go into the matrix, what is the item they go into after the matrix.
I cannot find a heater pipe layout plan
Many thanks
Mick
  • Chatham, Kent
  • Rover Metro 1.8VVC
    • 3.0l Elite estate
Re: No heating/ tepid
« Reply #1 on: 07 October 2018, 12:32:14 »
If you have hot water going to the matrix but no heat from it, then it's blocked. Flushing it can help, but won't solve the problem.
I had to do mine each winter, yet it took over 30minutes to get warm. When I fitted a new matrix, the heater got hot in about 1.5miles.
Curiosity made me remove the end cap off the old matrix, and 3/4 of the tubes were so tightly packed with silt that I couldn't poke lock wire down them.
A new matrix costs less than £20, and even though it's horrible job to change following the OOF guide I would do that rather than waste time flushing another.
The two heater pipes than run through the bulkhead after the HBV go directly to and from the matrix; there is nothing else in the circuit.
« Last Edit: 07 October 2018, 12:33:55 by Nick W »
Chazza12
  • south yorkshire
    • 1996 2.0 16v CD estate
« Reply #2 on: 07 October 2018, 13:56:59 »
If you have a few day you not using car empty the water out of the heater and put a full bottle of Coca-Cola in there with 6 caps of string vinegar and leave it in there a few days . And the flush it out a good few times forward and backwards out in to a pan and filter it out to see if it worked at removing the build up.  Did it on a old rad and left it for a week and was completely cleans out  it had been sat in none moving vehicle for 15 years.  Donít worry about it fizzing itís jut bubbles inside the coke and vinegar. See if it works for you did not harm the rad I did it on.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #3 on: 07 October 2018, 14:05:28 »
you mean strong vinegar?
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #4 on: 07 October 2018, 14:10:30 »
what size bottle of coke Pepsi or coka.?
« Reply #5 on: 07 October 2018, 14:43:50 »
Coke is one of the most corrosive products you can consume ;D
The bubbles aren't the CO2 from the coke, they're the direct result of the chemical reaction occurring as the coke dissolves the radiator and its contents  ::)
It will do the job, but do not leave it more than a couple of days as once it has finished dissolving the scale deposits, it will start on the alloys and eventually the steel :y
noknowledgemike
  • hertfordshire
    • omega 2.6 estate
« Reply #6 on: 07 October 2018, 17:42:46 »
Gents, many thanks for your replies, much appreciated.
I will go for the replacement as alot of rubbish came out during flushing.
« Reply #7 on: 07 October 2018, 19:18:23 »
Carefully follow the short cut guide and you won't go far wrong :y
Migv6
  • Webs End.
    • 3.2 Elite & Merc 190D.
« Reply #8 on: 09 October 2018, 13:05:29 »
Use Fernox to clean the system out.  :y
Wish I didn't know now, what I didn't know then.
woojtoos
  • Poland
    • Opel Omega Bfl 2,5dti
« Reply #9 on: 11 October 2018, 08:08:06 »
Hello,
You can also try to reset climatronic (I have similar problem that my heating was rather bad and it worked).
Reset procedure:
- ignition on
- fan speed low (so you can hear flaps moving)
- press both Auto + Off for ~5sec
noknowledgemike
  • hertfordshire
    • omega 2.6 estate
« Reply #10 on: 15 October 2018, 16:51:13 »
Hi, well, changed the matrix. I have hot air when set to cold and tepid when set to cold.
Has anyone a picture of the pipework from the matrix to the? and from the HBV to the?
Basically where ALL the heater pipes run from and too?
When I bought the car someone had run a wire from where the pipes run from a pump? attached to the inner drivers wing across the front to a vacuum valve, and into the relay box.
I also got antifreeze smell and acrid smoke from the bonnet whilst heater was on.
I am at a loss, and if I knew what all the components and where they are situated were would really help.
I cannot find a workshop manual for this car, does one exist?
Thanks again all.
Mick
noknowledgemike
  • hertfordshire
    • omega 2.6 estate
« Reply #11 on: 15 October 2018, 16:53:25 »
Forgot to say, hot air in footwell, but cool air from the rear seat vent.
« Reply #12 on: 15 October 2018, 16:58:02 »
Haynes do one.  :y
Sounds like you have plumbed the hbv in backwards.
Smoke is never a good sign. But diagnosis over the phone/tinterweb won't work with previous butchery :-\
One for Serek in Huntingdon given your location.
« Last Edit: 15 October 2018, 17:00:47 by Doctor Gollum »
noknowledgemike
  • hertfordshire
    • omega 2.6 estate
« Reply #13 on: 15 October 2018, 20:39:22 »
Is Haynes for the older Omega, I cant find one for the 03 years?
How do I know if plumbed backwards? has anyone the pipe order and where they go too?
Thanks for all the advice
Mick
Tick Tock
  • Hereford
    • 2.5 V6 Facelift Estate
« Reply #14 on: 15 October 2018, 20:42:54 »
Not the best drawing in the world, but may be of help. Includes pump for winter pack option.
Omega 2.5 V6 Facelift Estates, a CD & a CDX both in the rare star silver colour.
Page created in 0.11 seconds with 21 queries.
