Author Topic: Rear wheel bearings?  (Read 981 times)
« on: 19 October 2018, 16:28:51 »
So big blue has a noise thatís been going on a little bit.
Itís coming from the rear and sounds a bit like the brake pads are catching. Took them out cleaned up callipers and it remains.
It varies in noticeable ness with road surface and speed. Can also feel the Ďpulseí through the handbrake. I canít detect play, but I rarely can to be honest.
Blue is now at 172k and I think they are both original.
With the back of the car in the air with engine on and in drive it is noticable. Wheels donít spin particularly freely if spin by hand so think there is resistance somewhere
Evident both side but passenger side is worst.
Thoughts? I was thinking brakes initially and could still be tempted to take the callipers off and give them a good clean but not very hopeful after the pad out clean didnít do a lot
Thinking now to chuck it in for both wheel bearings. No way am I attempting it myself if it is that.
amba
  • Medway towns
    • 2003.BLACK 3.2 ELITE
Re: Rear wheel bearings?
« Reply #1 on: 19 October 2018, 16:44:38 »
On my old Elite it was very evident when you applied more load to 1 side than the other ..either by steering at around 40/50mph or when turning at similar speed.
Agree with not whishing to attempt replacing yourself  ;)
LC0112G
« Reply #2 on: 19 October 2018, 16:47:22 »
Which pads have you cleaned up? The pads in the rear calipers, or the handbrake shoes inside the drums?
I'd be replacing the handbrake shoes before attacking the bearings. The bearings make a rumbling sound IME. And yes, the bearings are a git to change.
« Reply #3 on: 19 October 2018, 16:59:23 »
Normal pads. Shoes and disks all 2 years and 12000 miles old
Noise doesnít change a lot with the handbrake on
  • Chatham, Kent
  • Rover Metro 1.8VVC
    • 3.0l Elite estate
« Reply #4 on: 19 October 2018, 18:29:18 »
With some basic tooling, rear wheel bearings are a simple job. £30 part and 2 hours in the street for your first one.
    • R320 TDM850 SmartRoadster
« Reply #5 on: 19 October 2018, 18:41:50 »
Aren't rear wheel bearings Serek's forte?  :y :y
  • Cornwall
    • 3.2 Project MV6 Estate
« Reply #6 on: 19 October 2018, 20:14:02 »
You are too modest. Your idea of basic tooling goes a bit beyond the norm.
  • Chatham, Kent
    • 3.0l Elite estate
« Reply #7 on: 20 October 2018, 08:50:38 »
2 minutes snotting three pieces of scrap together on the car and a £30 generic bearing puller set? I'm a mechanic, NOT a technician
  • Cornwall
« Reply #8 on: 20 October 2018, 21:11:23 »
Tools that I used / couldn't have done without which I don't think most people have in their tool set are
3/4" socket set to undo the drive flange nut (a long 1/2" breaker bar might have worked but I don't like the amount of spring in a 1/2" bar)
3/4" torque wrench to do it up again afterwards
FWD bearing puller / removal set (same as NickW's)
If I had an extra long tri-square XZN spline bit I would have been able to remove two of the brake backplate bolts  and then use my bearing puller /separator set to press the axle out of the suspension arm (or I could have spent a couple of hours digging out the welder and finding suitable bits of scrap metal to make a copy of NickW's tool).
« Last Edit: 20 October 2018, 21:14:58 by Andy H »
  • Chatham, Kent
    • 3.0l Elite estate
« Reply #9 on: 20 October 2018, 22:50:24 »
I've done five now, and none of them have been tight to undo. Torquing them is right at the end of my wrench's limit, but  access is the problem due to the back-to-front design of the hub. If GM had used a normal bolt through CV joint, instead of one attached to the driveshaft, no special tools would have been necessary.
  • Cornwall
« Reply #10 on: 20 October 2018, 23:18:56 »
I have done one and it was tight.
If I can remember to order some extra long XZN bits I will happily change the other side if it gets noisy.
I could probably do the job in 2 hours if I could find all the tools (without having to turn my workshop upside down) and didn't drink too many cups of tea  ;D
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #11 on: 22 October 2018, 15:04:36 »
If its an Estate with 172k on the Clock my money is on it will be Wheel Bearings.
  • Chatham, Kent
    • 3.0l Elite estate
« Reply #12 on: 22 October 2018, 17:20:02 »
and probably the N/S one.
polilara
  • Finland
    • 2.6 Y26SE Elegance 2001
« Reply #13 on: 03 November 2018, 15:28:46 »
Should change my right side rear bearing, too:
1. Where to buy a suitable bearing pulling set like here in pic?
2. Are back plates still available - the plate where hand brake shoes are?
  • Chatham, Kent
    • 3.0l Elite estate
« Reply #14 on: 03 November 2018, 15:47:36 »
search Ebay for wheel bearing puller
I wouldn't bother changing the other bearing until it fails. If it fails.
What is wrong with the backing plate?
Page created in 0.116 seconds with 21 queries.
