Pages: [1] 2 3 4 5 6 7 8 ... 18   Go Down
Author Topic: Where is the OBD2 socket on a 2004 Astra 1.6 petrol?  (Read 148818 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« on: 03 November 2018, 15:55:18 »
Bought this car today, MOT failure, engine light on, and cannot find the OBD2 socket.
    • 530D M Sport, 330i Coupe
Re: Where is the OBD2 socket on a 2004 Astra 1.6 petrol?
« Reply #1 on: 03 November 2018, 16:04:22 »
Must be within reach of the driver by regulation... so if not under the steering column try the centre console area, On the later Zaf it was somewhere in the lower centre console IIRC so probably the same for an Astra
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #2 on: 03 November 2018, 16:06:25 »
There’s a plastic cover underneath the handbrake lever. Pull it up and your prize will be revealed 👍
RIP Paul Lovejoy
« Reply #3 on: 03 November 2018, 16:10:35 »
Two seven year old McDonalds chips, half a polo, plenty of fluff and hair and a toenail
Webby the Bear
  • Northampton
« Reply #4 on: 03 November 2018, 16:26:25 »
RIP Paul Lovejoy
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #5 on: 03 November 2018, 16:28:56 »
This
Try not to brake the clips though, it kind off pulls up one side then slides off the other.
« Last Edit: 03 November 2018, 16:31:02 by zirk »
« Reply #6 on: 03 November 2018, 16:38:01 »
Really? On my BMW it's under the bonnet.  :-\
terry paget
    • 3 Astras 2 Vectra
« Reply #7 on: 03 November 2018, 17:01:47 »
Thank you. That was well hidden!
Webby the Bear
  • Northampton
« Reply #8 on: 03 November 2018, 17:38:01 »
No worries......o2 sensor?
RIP Paul Lovejoy
« Reply #9 on: 03 November 2018, 18:46:00 »
Is it OBD I or OBD II though?
« Reply #10 on: 03 November 2018, 19:10:46 »
Good question!  Given that it has rudely been described as Victorian by our aristocratic member from Lincolnshire, it might be OBDI.  :-\
It has a big round plug and I have to use an adapter to use my code reader.  :)
« Reply #11 on: 03 November 2018, 19:13:40 »
Not seen a round plug OBD2. Must be 1
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #12 on: 03 November 2018, 19:58:57 »
OBD sockets(whether 1,2 or EOBD) are trapezium shaped, and must be accesible from the driver's seat.
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #13 on: 04 November 2018, 01:00:51 »
If Sir Tigger has an E39, the early model definitely had a round (OBD) Diagnostic Port in the engine bay but later E39's have the traditional rectangular socket behind a panel on the dash by the drivers right knee (UK spec). My mate had both models so I know that's the case.  :y
I believe that some models ended up with both connectors present. If the dash connector is there, it will be behind another flap with OBD marked on it.
« Last Edit: 04 November 2018, 01:18:20 by YZ250 »
« Reply #14 on: 04 November 2018, 02:01:12 »
https://en.wikipedia.org/wiki/On-board_diagnostics
Basically 2001 on in europe ;)
My '51 525s was under the column as described above, as is the Trolley... The trolley's stalemate has a socket under the bonnet but only late models(' 98/99) have one under the dash, and then it's pot luck ;)
Pages: [1] 2 3 4 5 6 7 8 ... 18   Go Up
