Pages: 1 2 [3] 4 5 6 7 8 9 10 ... 18   Go Down
Author Topic: Where is the OBD2 socket on a 2004 Astra 1.6 petrol?  (Read 14520 times)
henryd
  • Moaning Haddock Head
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Where is the OBD2 socket on a 2004 Astra 1.6 petrol?
« Reply #30 on: 05 November 2018, 08:09:45 »
No worries......o2 sensor?
I suspect so. My cheapo reader said 'Lean mixture bank one'. The car has 2 lambda sensors, so could be either. I cancelled the code and it has not reappeared yet, but I cannot go far until I get an MOT certificate.
Once again, that does not necessarily mean that the lambda sensor is the fault. Whats more likely is that the sensor is reporting a fault further up the system. Changing the sensor will not fix the fault.
Reading the codes is just the start of the diagnostic procedure.
other rides
  Saab 9-5 Aero HOT estate,Focus 1.6 mk2,Pug 306 cabriolet
« Reply #31 on: 05 November 2018, 08:35:16 »
Late G as all H have 5 stud hubs ;)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #32 on: 05 November 2018, 10:57:15 »
Here's the disc.
probably the original GM discs ,
about the same condition that the Zafira discs where, with 9 months MOT
I chose to replace them with new because i stripped and cleaned the brakes
the pads where pretty much seized to the calipers
massive improvement of brake and handbrake once refurbished  :y
is this 2004 a late G or early H ?
I do like the simplicity of astra to work on
G or H, I don't know. Engine code is Z16XEP. You tell me.
Z16XEP is the Twinport engine fitted to late G  and early H  ;)
depends on spec and engine ,1.6 came with 4 or 5 stud  :y
H is this shape H 1.6 clicky
G is this shape G aport 1.6 clicky
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #33 on: 05 November 2018, 12:34:03 »
terry paget
  • Midsomer Norton Somerset
    • 1 Omega 3 Astras 2 Vectra
« Reply #34 on: 05 November 2018, 13:00:56 »
You are absolutely right mate. If u go back to the same place they’ll want to see the discs done. Just do them and be done.  :y
The car was tested in Warminster, miles away. New discs are ordered, so I will fit them.
On the other point, is an engine light on an automatic fail? I have read of cars passing MOT with engine lights on year after year.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #35 on: 05 November 2018, 13:31:47 »
section 8  Nuisance
Engine Malfunction Indicator Lamp
defect (h) Engine MIL inoperative or indicating a malfunction. FAIL category MAJOR
deviator
  • Chesterfield
« Reply #36 on: 05 November 2018, 13:38:05 »
2004 will be Astra H and OBD2.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #37 on: 05 November 2018, 13:45:35 »
can be Astra G or H as per 2004 example links above  :y
or even 2005 registered astra G mk4
hence why I asked if it was a G or H  ;D
terry paget
« Reply #38 on: 05 November 2018, 14:06:27 »
It's an H.
    • R320 TDM850 SmartRoadster
« Reply #39 on: 05 November 2018, 15:20:11 »
If you don't know how are we going to know  ::)
deviator
  • Chesterfield
« Reply #40 on: 05 November 2018, 15:25:16 »
Not when the OBD port is below the hand brake, it's got to be a H. The G was above the fuse box.
  • Up North
    • Astra 2.0 diesel
« Reply #41 on: 05 November 2018, 15:39:04 »
An astra G looks very different to an astra H. A quick google would have told you straight away.
If you are offended by anything I post, sorry. Just thought I'd get that in now.
deviator
  • Chesterfield
« Reply #42 on: 05 November 2018, 15:45:19 »
Hang on, I might be gettin confused, ignore me  :-[
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #43 on: 05 November 2018, 15:54:10 »
section 8  Nuisance
This 👍
RIP Paul Lovejoy
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #44 on: 05 November 2018, 15:58:19 »
astra F upto 98 obd port in fuses under wheel ish)
astra G 98 yo 2005 obd port under a cover in handbrake area
(worthy of note :x16SZR is not obd2 /no pedal test but you can flash paper clip test )
astra H 2004 port is near handbrake in console
Pages: 1 2 [3] 4 5 6 7 8 9 10 ... 18   Go Up
Page created in 0.152 seconds with 22 queries.
