Pages: 1 2 3 [4] 5 6 7 8 9 10 11 ... 18   Go Down
Author Topic: Where is the OBD2 socket on a 2004 Astra 1.6 petrol?  (Read 148701 times)
Re: Where is the OBD2 socket on a 2004 Astra 1.6 petrol?
« Reply #45 on: 05 November 2018, 16:41:46 »
Additionally worth know is that Astra-H is CANBUS, Astra-G is traditional ECUs.
« Reply #46 on: 05 November 2018, 19:58:04 »
..... The G was above the fuse box.
Not on the Astra G diseasals I had  ;)
« Reply #47 on: 05 November 2018, 19:59:31 »
An astra G looks very different to an astra H. A quick google would have told you straight away.
Hang on, I might be gettin confused, ignore me  :-[
I have ....  ;D ;D :-*
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #48 on: 05 November 2018, 22:03:59 »
G or H, I don't know. Engine code is Z16XEP. You tell me.
If you don't know how are we going to know  ::)
It was the grille wot gave it away
« Reply #49 on: 05 November 2018, 22:56:36 »
It was the grille wot gave it away ...
terry paget
    • 3 Astras 2 Vectra
« Reply #50 on: 06 November 2018, 07:23:00 »
On the journey home I noticed  a clonking noise at the front of the Astra, similar to the noise on my Omegas when the drop link end bushes are gone. I cannot see any drop links on the Astra. Any idea what could be the cause?
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #51 on: 06 November 2018, 07:26:29 »
Yes. Drop links 😂😂😂😂
Corsas and Astra’s terrible for them 👍
RIP Paul Lovejoy
« Reply #52 on: 06 November 2018, 08:50:27 »
... I cannot see any drop links on the Astra.  ....
Same place as an Omega ... at either end of the anti-roll/torsion bar  ;)
terry paget
    • 3 Astras 2 Vectra
« Reply #53 on: 06 November 2018, 17:30:45 »
Once again, Haynes, removing the drop link on a new car, simply states 'unscrew the nut and disconnect the anti-roll bar link rod from the strut.' After 12 years out in the mud and rain I expect mine are rusted near solid. Any tips?
« Reply #54 on: 06 November 2018, 17:46:03 »
Spanners. hammer, blow torch, WD40, hacksaw, brute force and ignorance.  Not necessarily in that order Terry, but no different to any old car really.  ;)
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #55 on: 06 November 2018, 17:53:32 »
 4.5" Angle grinder. You must have one, as you've got an electric welder.
You spent more time typing the post quoted above than you will removing both droplinks. Don't make this complicated!!
Webby the Bear
  • Northampton
« Reply #56 on: 06 November 2018, 18:24:58 »
What Nick said.
You may have luck with the Allen key / holding the nut if u soak it in wd and wire brush the threads. However if it gives u any hint of fighting then see Nicks post. Just do it carefully so you don’t cut the roll bar and/or strut link mount flange thingy. 👍👍👍
RIP Paul Lovejoy
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #57 on: 06 November 2018, 18:51:56 »
IIRC astra drop links have 16mm :-\ flats on the back to stop the ball turning
I have a thin spanner that i use for them
I have used an angle grinder in the past  ;D
terry paget
    • 3 Astras 2 Vectra
« Reply #58 on: 06 November 2018, 19:37:59 »
Thank you gentlemen, lots of good advice there. I will report back how I get on.
  • Chatham, Kent
« Reply #59 on: 06 November 2018, 22:13:48 »
So do I, which I use first. But if that's at all difficult, I go straight to the grinder as it saves a load of faffing about.
Pages: 1 2 3 [4] 5 6 7 8 9 10 11 ... 18   Go Up
