Author Topic: Very stange TV / android / router issue  (Read 658 times)
Re: Very stange TV / android / router issue
« Reply #15 on: 09 November 2018, 17:50:04 »
The android box was all they had in the last place. No tv signal at all. But did have fibre. So the android box met all their tv needs.
  • Millennium Man
    • The missus mad
« Reply #16 on: 09 November 2018, 17:53:24 »
The ring wire acts as a decent aerial. The usual problem is it injects noise onto the B leg, which causes (mostly CRC) errors, and ADSL resyncs. Generally worse in hostile RF areas, or when Christmas lights are on/flashing.
In this case, sounds like one or more of the devices are electrically noisy, and the ring wire is picking that up.  Suspect Sammy needs a chat with some of the devices ;)
I don't tolerate bickering, and I'm always grumpy.
And Lizzie Zoom says I'm a heartless bastid...and she's absolutely correct!
    • 3.2 MV6 (LPG), Westfield
« Reply #17 on: 09 November 2018, 21:42:52 »
Yep, the symptom is gone, but the cause is probably still there, in that the HDMI cables are radiating something nasty. Are they cheap looking cables?
I ask as, if they're prone to radiating interference, they're equally prone to collecting it, so they might find the picture / sound on the TV drop out every so often.
Good to have got to the bottom of it, though. :y
Must sort the wiring here some time as the muppets who built the place connected one wire out of each pair to the A, B and ring lines on the faceplate. ::)
Not an issue with ADSL as I've got a filter faceplate, but there are some nearby sources of RF interference that might upset blow the @rse out of the phones. ;D
« Reply #18 on: 10 November 2018, 08:16:20 »
Ive certainly seen better cables ;)  I know money is tight currently, so unless theres a problem, it wont be remedied....esp as the clutch bleed lasted a day before no clutch again, no great suprise, but probably means the end of the car
« Reply #19 on: 10 November 2018, 10:51:51 »
Fair enough, but worth bearing in mind in case of further issues. :y
« Reply #20 on: 10 November 2018, 12:48:45 »
Definately, although the clutch pedal has self healed over night, must be an airlock somewhere.
Page created in 0.1 seconds with 21 queries.
