Author Topic: Indicator Relay  (Read 139 times)
MikeDundee
  • Costa Del Peckham
  • avatar borrowed from DLK for a bit.....
Indicator Relay
« on: 01 December 2018, 09:33:14 »
Have a replacement relay but struggling to find out where it is, assume either under the steering column or in the engine bay, and which one is it?, been trying to find diagram and nothing in haynes :-\
  • Millennium Man
    • The missus mad
Re: Indicator Relay
« Reply #1 on: 01 December 2018, 11:12:06 »
If you imagine those relays under the steering wheel as a block of 9, in a 3x3 grid (with the diags socket taking the space of 2 relays), its the centre one.
If the indicators are malfunctioning, repeatedly press the hazard switch 30 times, and see if that improves it - the contacts in there seem less reliable than the relay ;)
I don't tolerate bickering, and I'm always grumpy.
And Lizzie Zoom says I'm a heartless bastid...and she's absolutely correct!
  • Millennium Man
    • The missus mad
Re: Indicator Relay
« Reply #2 on: 01 December 2018, 11:13:03 »
So centre column, middle row, next to diag socket.
MikeDundee
  • Costa Del Peckham
Re: Indicator Relay
« Reply #3 on: 01 December 2018, 11:33:48 »
Managed to work it out no 5, found a diagram, and then low and behold the indicators are now working :y :-\, so have a spare relay, thanks :y
Page created in 0.106 seconds with 22 queries.
