Author Topic: Child Seat Detector  (Read 681 times)
  • Solihull
    • 3x 3.2 V6 Elite Saloons
Child Seat Detector
« on: 02 December 2018, 19:34:45 »
Can this be disabled? Can't find a definitive answer.
Airbag light keeps illuminating and the code refers to this module. Can the appropriate connection be removed and the CSD option be disabled? Plenty of Elites around without the CSD so surely there must be a programming option on the ECU?
Really don't want to get into dismantling the seat on this car if I can help it.
Re: Child Seat Detector
« Reply #1 on: 03 December 2018, 07:25:10 »
Compare airbag ecu part numbers across your fleet...
If all the same then hopefully a simple tech 2 job. If no, then you might need to Improvise.
Not sure when, but if I get a chance I'll see if the wiring diagrams shed any light on it...
What year is it?
  • Solihull
« Reply #2 on: 03 December 2018, 07:36:49 »
Registration is 02.
I know you can fit a seat with a CSD to a vehicle that isn't set up for it and it works without issue  :-\
pompilius
  • Estonia
    • 2.6 FL
« Reply #3 on: 03 December 2018, 09:19:41 »
Hello!
I had a similar problem with the child seat detector, which turned the airbag light on. I was under the impression, that airbag controller can be programmed only once, so I just got another from a car without this option. I did receive one without the person detection option however, so had to disconnect the big yellow plug under the passenger seat.
The airbag controller lives under the armrest, takes some torx screws to get it out.
Rainer
  • Millennium Man
    • The missus mad
« Reply #4 on: 03 December 2018, 17:48:04 »
I don't think it can be programmed out once enabled.
SRS ECUs must be two-a-penny now. Just pop anther in (after removing cable for the sensor.
I don't tolerate bickering, and I'm always grumpy.
And Lizzie Zoom says I'm a heartless bastid...and she's absolutely correct!
« Reply #5 on: 03 December 2018, 18:04:10 »
Not sure a second hand one is a good idea if they are impact sensitive  :-\
  • Solihull
« Reply #6 on: 03 December 2018, 19:11:27 »
I could but they all have CSD!
  • Solihull
« Reply #7 on: 03 December 2018, 19:23:16 »
Might take the back plastic panel off the seat and see where the sensor is.. Might be a case of a crumbling connector if I'm lucky - this car has 205k on it (although the passenger seat won't have been occupied for all those miles) so has seen a bit of use.... and every passenger seems to want it setup differently!!
Main connector block at sill has been checked.
If all fails I'll have to look at an SRS ECU. MOT not till April so got a bit of time.... I'll Just reset the code for now.
« Reply #8 on: 03 December 2018, 19:41:49 »
Doh ;D
  • Millennium Man
    • The missus mad
« Reply #9 on: 04 December 2018, 17:15:06 »
Its a seat strip down :(
Get a SRS from a breaker, non elite, as many later elites had this option included as standard.
  • Solihull
« Reply #10 on: 04 December 2018, 18:50:21 »
OK, no coding required? Just disconnect battery, swap out unit, reconnect battery...
  • Millennium Man
    • The missus mad
« Reply #11 on: 06 December 2018, 18:18:53 »
Aye.
  • Millennium Man
    • The missus mad
« Reply #12 on: 06 December 2018, 18:19:38 »
Ensuring its right one for car. I *think* any post MFL would be ok
  • Solihull
« Reply #13 on: 06 December 2018, 20:09:45 »
What can possibly go wrong  ::)
« Reply #14 on: 06 December 2018, 20:49:46 »
Changing all four airbags should only take a couple of hours...  ;D
Add an hour for the pretensions as the seats need to come out...
Page created in 0.118 seconds with 21 queries.
