Author Topic: Recommended Camber (front)  (Read 731 times)
polilara
  • Finland
    • 2.6 Y26SE Elegance 2001
« on: 21 December 2018, 09:48:22 »
Just going to alignment after new everything in front. Remember there was some recommendation for camber, cannot find it now, please help.
biggriffin
  • huntingdon, Hoof'land
    • 02 3.2 mv6 estate.
Re: Recommended Camber (front)
« Reply #1 on: 21 December 2018, 10:03:32 »
1'10.
Hoof'land storeman..
Omega is a barge not a dtm-touren-wagen
polilara
  • Finland
« Reply #2 on: 21 December 2018, 10:09:53 »
Thanks, just in time (perhaps minus 1'1)
polilara
  • Finland
« Reply #3 on: 21 December 2018, 10:10:49 »
Sorry I mean -1'10
« Reply #4 on: 21 December 2018, 10:42:19 »
Sorry I mean -1'10
That's the one  ;)
polilara
  • Finland
« Reply #5 on: 21 December 2018, 11:15:02 »
Once again -1°10'
« Reply #6 on: 21 December 2018, 12:26:15 »
Once again -1°10'
Hang on, let me check...
Yup, still the same ::)
polilara
  • Finland
« Reply #7 on: 21 December 2018, 13:03:44 »
Thanks, good to know the recommendation as the factory tolerance is quite large. Now it was terrible to drive as everything is renewed and all angles are totally wrong, keep you informed how good it is after alignment and new parts, riding height also increased.
« Reply #8 on: 22 December 2018, 11:16:09 »
That's why the phrase 'in the green' attracts such disdain... The Omega being a fussy sod ;D
Jan Suhr
  • Nyköping, Sweden
    • 2 Omega Caravans 3.2 V6
« Reply #9 on: 22 December 2018, 15:04:38 »
The shop I used last week, after I had changed the front suspension with new struts and springs, had -1.40 in their database. I had to tell him to go for -1.10.
Jan Suhr
Stockholm, Sweden
www.protouring.se
polilara
  • Finland
« Reply #10 on: 22 December 2018, 15:17:41 »
So, now aligned - really good to drive with everything new in front. Camber as discussed and toe in 1mm/side = 2mm. Also silent with new bearings, riding height 690 in front (Sachs springs). Thanks for all for tips, job jobbed...  next rear side bearings after Christmas.
Enceladus
  • London
« Reply #11 on: 22 December 2018, 20:45:19 »
That's because the official spec is -1°40' +/-45' with a max left/right difference of 1°. However only really works with a complete brand new original spec front suspension. IMO too sloppy especially when the whole assembly ages and wears and the front springs start to sag. Your -1°10 target is closer to the min than the max and is known to work better.
Total toe-in of 2mm? The spec is 0°10' +/-10'. I don't know how many mm this equates to? There is a TID advisory somewhere to increase the toe-in to the max limit, that's a total toe-in of  0°20',  where abnormal wear that is otherwise unexplained, occurs to the inboard edges of the front tyres.
Both front seats are supposed to be loaded with 70kg and the fuel tank full when the car is measured.
« Last Edit: 22 December 2018, 20:51:14 by Enceladus »
  • Northampton
    • 06 BMW 650i, 07 Cooper S
« Reply #12 on: 22 December 2018, 20:52:50 »
1mm is going to be somewhere around 8', so total toe of ~16' or thereabouts, assuming 17" wheels: http://www.trackace.co.uk/manual/conversion%20chart.pdf
..and it went 'dugga dugga dugga dugga' no more.
  • Chatham, Kent
  • Rover Metro 1.8VVC
    • 3.0l Elite estate
« Reply #13 on: 22 December 2018, 21:39:36 »
Does that link mean you've got a Trackace and if so, is it any good? I used to have some genuine Dunlop gauges until they were stolen, and the Trackace looks like an affordable way(storable too ;D ) of replacing them.
  • Northampton
« Reply #14 on: 22 December 2018, 21:48:55 »
Sadly no - I looked at them a while back, but they remain on the long list of things I'd like to buy if I had limitless money ;)
Page created in 0.104 seconds with 21 queries.
