Author Topic: Removing plug from driver's door motor  (Read 749 times)
terry paget
  • Midsomer Norton Somerset
    • 1 Omega 3 Astras 1 Vectra
« on: 24 December 2018, 15:46:05 »
3.2 ex-plod manual saloon
Daughter is now home with her Omega with failed driver's door lock. I am struggling to remove the plug from the locking motor. I can get my left hand on to the plug, can press together the 2 ears to release the plastic retaining clips, but cannot get enough force on it to wriggle it out.
I have done it in in the past, but cannot now. Old age? I asked my 40 year old son to try, he failed too. Please, gentlemen, is there a trick, a technique, to do it?
Re: Removing plug from driver's door motor
« Reply #1 on: 24 December 2018, 16:05:36 »
Release the inner handle and lock button rods, undo the three torx bolts securing the lock mechanism to the door and move the whole gubbins to where you can get two hands on it ;)
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #2 on: 24 December 2018, 16:38:40 »
fingernail behind the flaps one at a time and bend them out a bit and then push down,
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #3 on: 24 December 2018, 16:48:53 »
Some time ago now but I am sure that I released the operating cable from the inside bottom of the door to enable the motor to be lifted above the access hole The lock mechanism of coarse has to be freed from the door.The cable can be clipped back when the job is finished. Open up the plastic clips to release the plug.
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #4 on: 24 December 2018, 17:05:18 »
Yes, I had trouble reaching it and found it easier to undo its mountings to make it more accessible. :y
terry paget
« Reply #5 on: 24 December 2018, 17:14:19 »
Thanks for the quick response gentlemen. Doc G's method worked a treat. The cable restricted how far out I could pull the motor, but now I have it out I shall release the cable inside the door.
What's the best order of reassembly of reassembly?
biggriffin
  • huntingdon, Hoof'land
    • Vectra in a posh frock.
« Reply #6 on: 24 December 2018, 17:42:27 »
The reverse procedure to which you removed it
Hoof'land storeman..
Rwd-less..
terry paget
« Reply #7 on: 27 December 2018, 10:44:08 »
descendingJob completed early Christmas day. Thanks to all for help.
Having dismantled things carelessly, I reassembled as follows:
inserted lock assembly into door
plugged cable into solenoid
fitted pull up rod to locking lever (blue clip)
manouevered lock into position, with pull up rod through hole in door and outside opening rod into correct green hole
attached lock to door 3 torx screws
attached inside opening rod to top lock lever brown clip
attached central locking lever to lever bottom left brown clip.
Job is made tricky by poor access to door interior. Above shot was taken with wife's small camera.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #8 on: 27 December 2018, 13:26:25 »
Was it the locking motor that had to be changed?
terry paget
« Reply #9 on: 27 December 2018, 21:12:59 »
I don't think so, I heard it clonking away as I dismantled things. I made hard work of the job, and replaced the whole solenoid/lock assembly with a spare I had lying around. I reckon it was the lock itself that had failed, but that does not fit too well with the fact that my daughter ran the car for 2 months simply by leaving it unlocked every night. I have no way of testing the solenoid now that everything is assembled and working OK.
Checking continuity between pins in the socket. with the socket upright, the locating pin at the bottom, and numbering pins top to bottom 1,2,3 and 4,5,6 there is continuity beween 23,26,36,56.Not sure what that tells us, except that the solenoid is not dead.
« Reply #10 on: 27 December 2018, 21:18:33 »
Actually tells you nothing...
terry paget
« Reply #11 on: 28 December 2018, 21:09:17 »
Quite so.
Here is a pic of the two locks. On the left is my spare, the other is the suspect lock.
This pic is the dodgy lock.
Looks to me like the dodgy lock is stuck in the wrong position. I can push it back a little, but cannot pull it forward. Compare the 2 locks above, LH lock is the one I installed.
Furthermore, I can easily move the solenoid on the failed assembly, it ain't stuck. I reckon a bit broke off the lock catch and has jammed the lock. The RAC man somehow got the door open, and slammed it shut, but it was never latched shut.
terry paget
Dodgy lock bigger
« Reply #12 on: 28 December 2018, 21:17:18 »
Dodgy lock bigger
terry paget
« Reply #13 on: 28 December 2018, 21:26:50 »
3rd attempt
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #14 on: 28 December 2018, 21:46:23 »
Pictures of the back would be more informative  :y
Page created in 0.112 seconds with 21 queries.
